Old 01-30-2013, 05:06 PM   #11
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Rear cam plug for 184 bowtie block
I recall early small block Bowtie blocks having odd size rear cam plugs and also the small plug under the rear cap was different.
I built a few engines using them and they were the 184 casting numbers.
I really think I just sorted thru various sizes untill I got a good fit.
Measure the hole with a dial caliper and find a shallow plug about .010" -.015"smaller....
I always staked the plug in with a hammer and a blunt nose punch...
I have even epoxied them just to make sure they don't move or leak...
Rich Biebel
S/C 1479
Stock 147R
Old 01-31-2013, 12:18 PM   #12
Darrin Christen
Darrin Christen's Avatar
Daren, if it has stock size cam journals, and it turns out to have those two threaded holes, this factory piece is a nice heal. It's like a plug with an O ring, made on a flat plate with ears for the two screws. Slicker piece than a drive-in plug. I can't use it because I had 50mm roller cam bearings installed. The hole is too big now.
This block has 50mm roller brgs as well. Thanks to everyone for the help.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 01-31-2013, 03:07 PM   #13
FED 387
Liked 333 Times in 180 Posts
Darrin---after thinking about this try contacting Dart Machinery in Michigan they have a full line of parts that would probably fit your application--- cannot cost a lot either(they sell a whole freeze plug kit and block plugs for only $25) maybe even tell you the correct size your gonna need and tell you to go to the auto parts store---
Old 02-04-2013, 08:01 PM   #14
Darrin Christen
Thanks for everyones help on this. The block does have the bolt holes that Ed mentioned for the bolt on cam plug, but it has 50mm roller brgs. I ordered the one Jegs had listed for the Dart blocks and it was identical to the one that is in my bowtie block. It was only $.87 cents from Jegs! Might be the cheapest thing in the motor! The plug measures 2.394" and the bore in the block measures 2.387" in case anyone is wondering.
Old 03-13-2013, 01:02 PM   #15
ron mattson
Liked 68 Times in 31 Posts
The cam plug on the bowtie blocks with a std cam is 2-7/64 or a dorman
part number 555-080 for all current generation blocks with 2in bearing saddles.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 03-13-2013, 05:05 PM   #16
carl hinkson
Liked 18 Times in 10 Posts
If that the EPC-92 cam plug make sure you install it with the flat side out and cup side towards the inside!!!
Good luck
carl hinkson is offline   Reply With Quote
