Old 03-16-2013, 10:05 AM   #11
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: 1967 Pontiac Firebird
March 1967 (Super Stock and Drag Illustrated)
Old 03-17-2013, 08:39 AM   #12
Paul Ceasrine
Kip,
The 1967 Pontiac Firebird came with either the 400/325 HP or the 'optional' 400/335 HP 'Ram-Air'.
The 400/325 HP had the same,
* 10.75 - 1 Pistons
* Casting #670 Cylinder Heads (72.0 CC)
* 2.11" Intake / 1.77" Exhaust
* Cast Iron Intake Manifold
Note; To get a 'true {10.75 - 1 Compression-Ratio}, the Cylinder Heads would require a {65.0} CC Volume.
Differences;
400/325 HP - Camshaft
* .421" Intake / .424" Exhaust
* 273* / 289" Duration
* 47* Overlap
Valve Springs (Inner & Outer)
* 103 lbs. to 117 lbs. {Valve Closed}
* 239 lbs. to 257 lbs. {Valve Open}
400/325 HP- Rochester 750 CFM Quadra-Jet
* #7037263 (Manual)
* #7027272 (Automatic)
400/335 HP 'Ram-Air' - Camshaft
* .424 Intake / .424 Exhaust
* 301* / 313* Duration
* 76* Overlap
* 135 lbs. to 145 lbs. {Valve Closed}
* 287 lbs. to 303 lbs. {Valve Open}
400/335 HP 'Ram-Air' Rochester 750 CFM Quadra-Jet
* #7037273 {Manual}
* #7037276 {Automatic}
Old 03-17-2013, 08:32 PM   #13
Paul Ceasrine
1967 Pontiac Firebird 'H.O'
Called the 'Light Heavyweight'
With a 'special' 'High Output' 326/285 HP.
285 Horsepower @ 5000 RPM's
359 Foot Pounds/Torque @ 3200 RPM's
* 3.719" Bore x 3.750" Stroke
* 10.5 -1 Compressior Ratio
Featuring Casting {#141} 'High Compression' Cylinder Heads with
(52.0 CC) Combustion Chambers.
1.92" Intake / 1.64" Exhaust
Camshaft = .386" Intake / .421" Exhaust - 269* / 277* Duration - 47* Overlap
Valve Springs = (#95 lbs. = Valve Closed) - (#225 lbs. = Valve Open)
Carter AFB (600 CFM) - (1 7/16" Primary x 1 11/16" Secondary)
Dual Exhaust (2.00" Primary} - (2.25" Tail-Pipe)
4-Speed (M-20 Wide-Ratio) = 2.52 - 1.88 - 1.46 - 1.00
Clutch = 10.4" (6.5" Inside) - .140" Thickness - #2050 lbs.. Load-Rate
2-Speed Power-Glide Automatic
Gear-Ratio's = 3.08 - 3.23 - 3.36 - 3.55 - 3.90
Special Order Options;
* 4-Speed (M-21 Close-Ratio) = 2.20 - 1.64 - 1.28 - 1.00
* Turbo Hydra-Matic (3-Speed Automatic)
* 4.33 Gear-Ratio
Only 6078 Produced
Old 03-18-2013, 08:09 AM   #14
Paul Ceasrine
Kip,
The $64,000 question......
How many 1967 Pontiac Firebird's were ordered with an M-21 Close-Ratio 4-Speed, and 4.33 Gears.
Old 03-18-2013, 09:02 PM   #15
Paul Ceasrine
Kip,
'Zero'
Nobody ever ordered one.
Productions Numbers
Firebird - 326 'H.O'...................6078
Firebird - 400.........................18,632
Firebird - 400 'Ram-Air'...............65
Total.........................................24,7 75
Old 03-19-2013, 10:07 AM   #16
Paul Ceasrine
Kip,
The Turbo Hydra-Matic (3-Speed) was 'only' avaibable with the
Firebird 400.
The Firebird 326 'H.O' could 'only' get the 2-Speed 'Power-Glide'
for an Automatic.
Both the Firebird 326 'H.O' and Firebird 400 had;
* Special Suspension Package
* #345 lbs/inch Load-rate 'Front Springs'
* #135 lbs/inch Load-rate 'Rear Mono-Leaf Springs
* 5/8" Front Sway-bar
* Automatics had a Traction-Bar installed for the right rear.
* 4-Speeds had 'dual' Traction Bars
* 10-Bolt Rear-Ends
* Dual Exhaust
Note; The 400/335 HP 'Ram-Air' engine had '428' exhaust manifolds.
Note; The 400/335 HP 'Ram-Air' engine had a 'special calibrated'
Rochester 750 CFM Carburetor.
Note; 'Ram-Air' option (Cost; $263)
Old 09-13-2021, 12:35 AM   #17
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Probably nobody that cares, but there is some slight misinformation this thread.
First thing I'll say is that I've never heard of anybody running the 326 in a competitive Stocker. The holes are just too small.
But, can anybody here site any competitive 326 powered Stockers ?
The Pontiac 2-speed auto was referred to as a "power-glide". It's my understanding that all the '64-'69 Pontiac A & F-body 2-speed autos were not Chevy Powerglides, but were what some call a "Super Turbine 300". I think these were also used in some Buicks & Olds too. IIRC, they could use a TH350/TH400 type converter.
https://en.wikipedia.org/wiki/Super_Turbine_300
BUT, after '69, SOME Pontiacs did come with a PG trans. I think some of 'em came with a dual pattern case & some came with that same case, but only the BOP holes were drilled.
I only bought one of the dual pattern PG's. Actually bought the whole car(what was left of it) from a U-Pull-It yard. I think it was a '71 Bird. May have been a '70. When I unbolted it from the 350 engine, the bell housing part fell into several pieces. Couldn't tell it was cracked, because of all the caked on dirt. I only saw one other, which was in a Lemans. I wanna say that they only came in Pontiacs in '70 & '71, but could be wrong.
https://www.ebay.com/itm/293982744520
Name:	1 - Dual Pattern PG .jpg
ID:	59227   Click image for larger version
Name:	2 - Pontiac Glide .jpg
ID:	59228   Click image for larger version
Name:	3 - BOP Glide .jpg
Name:	4 - Pontiac PG .jpg
Old 09-13-2021, 01:00 AM   #18
oldskool
oldskool's Avatar
" A couple of little tricks, and you could get them to run high 13.00's, and still drive them on the street."
I doubt that, seriously.
Very few '60's & early '70's big engine Musclecars would run 13's, on the street. Most ran 14's. My '69 366hp GTO would barely run 13's, with hard street tires, and that was with 3.90 gears. Would take some serious changes from a stock 326 Bird, to get the little 326 to run in the 13's, and still be streetable, IMO.
But hey, what do I know. There may have been 13 sec 326 powered Birds in almost every area that had a Pontiac dealer. I certainly never ran across one.
Old 09-13-2021, 01:45 AM   #19
oldskool
oldskool's Avatar
Since this thread was started nearly 10 years ago, I'll update it a bit.
Since the thread was posted, there have been two 10 sec '67 Birds. Most all Stock/SS racers know about Randi Lyn Shipp's '67. She's won at least 7 nat events, may be 8 now. I forget.
And, most Pontiac Stock/SS racers know about Bryan Phillips's '67 Bird. It also runs 10's & has qualified near the top, at lots of races. Don't know if he's won a nat event or not. But he has won some smaller races.
Joel Larkin has the only '67 SS Bird I know of that's still active.
BTW, notice in pic #4 that Randi Lyn's '67 400 Bird has what appears to be the 326HO stripes.
Name:	1 - Comin atcha .jpg
ID:	59231   Click image for larger version
Name:	2 - '67 Bryan Phillips .jpg
ID:	59232   Click image for larger version
Name:	3 - Joel Up .jpg
Name:	4 - 326HO Stripes .jpg
Old 09-19-2021, 01:25 PM   #20
oldskool
oldskool's Avatar
Continuing with the subject of the thread, I have pics of some '67 birds from back in the old days.
The 1st 5 are of Stockers. #5 is OHC Six powered.
Roy Gay, of Gay Pontiac in Southeast TX, drove a '67 Bird in Super Stock. Don't have any record of times turned or race results.
Another '67 was driven by Tony Knieper. Looks like it may have been sponsored by Gratiot Auto Supply & Stan Long Pontiac. Pic caption says the car held a nat record.
Name:	1 - Super Bird .jpg
ID:	59644   Click image for larger version
Name:	2 - Myrtle Motors .jpg
ID:	59645   Click image for larger version
Name:	3 - B + B .jpg
Name:	4 - LMP .jpg
ID:	59647   Click image for larger version
Name:	5 - OHC 6 .jpg
ID:	59648   Click image for larger version
Name:	6 - Gay SS-DA .jpg
Name:	7 - Gay '67 SS .jpg
ID:	59650   Click image for larger version
Name:	8 - Tony Knieper .jpg
ID:	59651   Click image for larger version
Name:	9 - Stan Long & Gratiot .jpg
