Old 03-21-2013, 12:22 PM   #21
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: how to speed up my pure stock 305 Camaro
For Mufflers..I like Spintech the best ..
Enjoy that my ears are not ringing at the end of the day.!
BTW my car still has working AC and love cooling down a bit after a run
D
So true.
"The dreaded blowmaster drone..." lol
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-21-2013, 01:45 PM   #22
Ed Wright
Ed Wright's Avatar
Originally Posted by ALMACK View Post
Ed:
Are you running racing fuel ?
I might experiment with the lower temps. Not sure how it will work with a 9 to 1 engine on unleaded pump gas.
Alot of the reason I run at those temps are for round robin (consistency) purposes. Easier to get the water temp down to 160 than it is 90 degrees between rounds.
I'm still using the OEM computer and sensors even tho the IHRA rulebook does not say a racer cannot run an aftermarket ECM. ( if I read that correctly)
All I did on my car was set the dizzy and leave out the spout connector so the timing is locked @ 32 deg.
When I was still driving mine on the street on pump gas, it was still quicker cooled down.
That GM car has a plug-in chip. Uses the stock ECM. I can/have made stock looking chips for limited classes that don't allow chips. LOL
Ed Wright 4156 SS/JA
Old 03-22-2013, 01:56 AM   #23
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
the tbi engine such as 305 can run with the timing connector unplugged to run at a base timing too. unlpug it and set the timing to 32-34 at the track, set back to 0-4 and plug in for the drive home
Old 03-22-2013, 07:49 AM   #24
Chris1529
Liked 70 Times in 29 Posts
do those cars have an adjustable fuel pressure regulator on them?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-22-2013, 10:39 PM   #25
Ed Wright
Ed Wright's Avatar
You can, but it then runs in "Backup Fuel Mode". I don't know what the WOT air/fuel ratio would be then.
"Do they have adjustable fuel pressure regulators?"
No, but they can be made adjustable.
Sure crude-azzed ways to try to tune one. Lmao!
Old 03-24-2013, 01:41 PM   #26
randall502
Got headers and mufflers on yesterday and going to change oil to synthetic. Hopefully this will pick me up some.
randall502 is offline   Reply With Quote
Old 05-27-2013, 08:22 PM   #27
david christy
my 88 monte ss is retired from pure stock but still will run 8.7s all day let me know how your coming out. that tbi motor runs way lean to begin with(hope you got a better fpr). I put one on my 87 suburban and it ran a lot better 3800lbs 10.30 1/8 mile and 20 mpg with 3.08's.
david christy is offline   Reply With Quote
