Old 03-24-2013, 11:15 AM   #11
Run to Rund
Liked 56 Times in 29 Posts
Default Re: Interesting new Rule coming in 2014
I hope NHRA is not talking about the old style bolt on collector extensions that use the 3-bolt flange. I would think three 3/8" bolts with a 1/4" thick flange would be sufficient.
Old 03-24-2013, 11:44 AM   #12
Glenn1066
Red face Re: Interesting new Rule coming in 2014
My collectors end at my transmission cross member, so I drilled a hole through the cross member and the collector, installed a grade 8 bolt double nutted. I check my nuts before each run (hum that doesn't sound right!). I wonder if that will pass tech next year.
Glenn
Glenn1066 is offline   Reply With Quote
Old 03-24-2013, 02:28 PM   #13
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Interesting new Rule coming in 2014
Glenn
Shouldn't be a problem,, just make sure you tell the tech person, that you check
your nuts before every run! I know,,, I just had to do it!
Danny Durham
Old 03-24-2013, 04:20 PM   #14
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
We have Mark's slip on collectors on all 4 of our cars, thousands of runs between them,never lost a collector yet.
Grade 8 1/4 20 Allen bolts lock washers and nyloc nuts do the job just fine at a cost of less than $5 per car.
JUST WHO OWNS SFI ANYWAY?
Istill have a major hard on for Lokar after stiffing us on a $50 contingency payment for a trans dipstick and tube so we won't be using or selling any of their stuff anytime soon no matter what!
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 03-24-2013, 10:24 PM   #15
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by brent flynn View Post
rediculous... Is there that many guys, who cant keep their collectors from coming off, to warrant something like this? My collectors have 2 tabs, per collector, with bolts, that will keep them from coming off... never had a problem... Jam nuts will cure this problem, not some costly device....
YES I just missed a set coming off a car at Cecil County Dragway last November and in the traps.
In fact one earlier in the year but did not have to take drastic action like the Cecil incident.
D
Old 03-26-2013, 01:01 AM   #16
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
If anybody was at Atco a few years ago and saw the end result of a collector coming off a T/S car doing a burnout you'de understand the reasoning for having a collector retainer.Maybe not the crap that NHRA is going to implement though.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-26-2013, 09:41 AM   #17
Frank Bialas
Frank Bialas's Avatar
Liked 24 Times in 14 Posts
Originally Posted by Myron Piatek
So this "tether" will keep any loose exhaust tubing "contained" under your car, potentially bouncing around and beating on your fuel/trans lines, oil/trans pan and/or the driveshaft?
I also wonder if this has any affect on cars using full exhaust systems, with or without mufflers.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 03-26-2013, 09:48 AM   #18
Frank Bialas
What about an exposed brake line, or if you get really lucky and it hits/bangs your shifter linkage say maybe into reverse @ 130 MPH, Then what??? Mark A56 has the best idea, don't even get yourself in this situation, any of the above mentioned and have your STUFF correctly install/mounted in the first place, [NIP IT IN A BUD]
Old 03-26-2013, 10:54 AM   #19
FED 387
Liked 336 Times in 183 Posts
not totally familiar with what NASCAR uses but they use adjustable headers and the "spring type" retainer set up they use seems to solve their problem -- never have seen a collector come off and they run em 600 miles at 195 MPH for close to 5 hours ----may be a way to solve any potential problem
Old 03-26-2013, 11:17 AM   #20
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Originally Posted by A56 View Post
Not all of us can weld our collectors on, those of us with real race headers would never get them on and off the car.
Mark Lelchook
D/ED F/SA
I fully agree, Alex just loves installing the headers now, we would have to lift the engine way up if we welded them on. That would be a nice added feature in teardown.
I was at Indy several years ago when a '68 S/S Cobra Jet lost a collecter in the waterbox, he powered over the collector and sent it into a bystander to the right of the water. It was not a pretty experience.....
Like Mark said, it could save someone from getting hurt, but, there are several avenues to end up with the same result.
Wade
