I have an issue with my small block chevy . The piston is .002 over the block on the left cylinder bank and .002 down on the right bank . Is it legal to use a thicker head gasket to correct the piston deck clearence ?
Thank! |
Liked 719 Times in 220 Posts
Yes. The .004" difference probably would be insignificant otherwise. Next time its down for a rebuild, get the deck heights equalized.
I am not sure you can run a deck above block. That is the way the rule use to read.
Liked 92 Times in 29 Posts
If deck height is suppose to be below deck that's what it has to be. Even when it's suppose to be above block it has to be above.
At least that's the way I remember it. |
Oops. I didn't remember the legality of that issue. I never had a plus deck engine like that. Better find a way to make it a minus deck engine. If you have rods with the small end bushed, it might be wise to rebush them and offset the pin bore a few thousandths. Otherwise, it's block time again.Best wishes on your project!!
Since we are talking an SS engine, just deck the pistons.
Ed Wright 4156 SS/JA |
Guys , That plus deck , minus deck rule had been rescinded 6-7 years ago.
I remembered that, but I called the guys at Rick Watters to confirm. They build them either way as long as the math adds up, and have been for a while.
Liked 3 Times in 1 Post
Check section 11a pg 3" Gaskets" in 2013 NHRA rule book
Liked 10 Times in 7 Posts
In the STOCK section 10A page 4 in the ruel book under GASKETS.
Good! It's very clear in the rule book. Yes, you can use a thicker head gasket to compensate for the deck height being insufficient.
Class racer is full of good tech info . Thank! everybody for your help. Sincerely! |
