Old 03-31-2013, 06:41 PM   #1
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Your M,N,O class 60ft.
What does your stocker 60 ft & is that with/without a "low" gear set in the trans. Just seeing roughly where I need to be.
Dave Noll, EF/S ,?/SA 6526
Old 03-31-2013, 08:24 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: Your M,N,O class 60ft.
mine was 1.60 to 1.65 with a stock c-4 ratio.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-31-2013, 10:29 PM   #3
We have been 1.55 in O/SA...350 Buick, 2.74 low, 4.56..,245 mm converter
That would be kind of an outlier on the graph though...
Old 03-31-2013, 11:17 PM   #4
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Best of 1.62 in N/SA.
Bob Don 128 SS
Old 04-01-2013, 08:52 AM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Your M,N,O class 60ft.
1.65 in O. It's a rather heavy Chevelle station wagon.
Old 04-01-2013, 09:02 AM   #6
Hemidude
Hemidude's Avatar
1.59 in M, 273CI, 2.74 first gear, 4.86 in the rear.
F504 C/SA , Tracy Fairchild
Hemidude is offline   Reply With Quote
Old 04-01-2013, 02:42 PM   #7
GTX JOHN
1.498 @ Sea Level
0/SA dodge Wagon
318 Low Perf. small valve
3625 Lb.
Usually `1.52 to 1.54
Loooooooooow Gear Pro Trans with Straight Cuts and all Goodies.
Old 04-01-2013, 05:38 PM   #8
65signet
Liked 49 Times in 22 Posts
What size tire do you run?
Thanks
65signet is online now   Reply With Quote
Old 04-01-2013, 05:57 PM   #9
Rory McNeil
My M/Stick car only runs low 1.6s to 60 feet, I am sure that the combination of a fat driver (no ballast in the trunk), and bias slicks likely do not help. I do not know how other lower classed stick cars compare to similar automatics.
NHRA 6390 STK
M/S 85 Mustang
Old 04-01-2013, 06:01 PM   #10
Hemidude
Hemidude's Avatar
Thanks
26 tall, 8 wide. About all the room there is.
elev. at Brainerd where I mostly run is 2500-4000 feet.With a low barometer.
