Old 04-09-2013, 10:25 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Front tire for slower stocker
Any advantage to a taller tire for a slower stocker N/SA. New build and putting on the final touches. Thanks
House of Darts is offline   Reply With Quote
Old 04-10-2013, 02:48 AM   #2
GTX JOHN
Default Re: Front tire for slower stocker
We run 28 Goodyears on Kids N/SA.
Old 04-10-2013, 07:45 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Front tire for slower stocker
A taller tire will provide more rollout for slightly faster ET's IF you stage shallow. But it can also increase overall reaction times, which tend to be slower in a slower stocker. Then you have to make adjustments to yourself and your staging technique to find a comfortable spot on the tree.
Old 04-10-2013, 10:21 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
Tire clearance to the body may become an issue. You don't want them to rub the tops of the fenderwells after launch, for example. Wheel offset may have to be exactly correct, limiting the selection of wheels.
Old 04-11-2013, 06:31 AM   #5
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I run 28 on the front.
Bob Bender 144 O/SA
Old 04-12-2013, 10:09 PM   #6
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I would be interested to know what the e.t. difference would be between a 28 " front vs. a 25.5-26 " front. (with all else being equal and barely staging the same)
My P/SA has 28's on the front.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 04-20-2013, 08:10 AM   #7
philbilly
philbilly's Avatar
There was no et difference at all from 27.5 to 23 inch tires. However the reaction was definitely better.
In the early days when photocells was all jacked up yes maybe et difference. But in today's world they set starting line beams way to low. With the 23 in tires I have app 4 inches of rubber on the ground the same for the 27.5. Maybe half inch more where the beams hit. If the beam hit the middle of the wheel I woul agree but it doesn't. Old timers philosophy
philbilly is offline   Reply With Quote
Old 04-20-2013, 08:20 AM   #8
philbilly
philbilly's Avatar
Anyone really want to find out. Get a tape measur and start pullin some measurements with proper air pressure and then go make some runs. You will be surprised. 60 bulbers can turn into 20 bulbers real quick and make the cars look better.
Old 04-20-2013, 09:26 AM   #9
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: Front tire for slower stocker
I don't know what size they are,but I would get the same ones that are on Jody Lang's wagon.
Old 04-20-2013, 11:22 AM   #10
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I went from 28" to 26". I got better reaction and slowed about .05.
Bob Don 128 SS
