Old 04-09-2013, 09:49 PM   #21
Jeff Lee
Jeff Lee's Avatar
Default Re: 396/375 hp/motor issues
Last time I had a car with that Petronix in it it ran pretty much as you are describing. It was in the car when I bought it. I went to auto zone, paid about $55 for a rebuilt single-point distributor and the AMX instantly ran perfect. Also picked up about 800 RPM.
Pull one plug wire at a time, ground it and see if you have spark out of all 8.
Jeff Lee 7494 D/S '70 AMX
Old 04-09-2013, 09:57 PM   #22
christopher teed
i will give it a try Jeff.thanks...with the timing light hooked up ,timing mark it is steady for about 5 or 10 seconds them its instantly jumps about 20 degrees.starting to make altittle more sense.
christopher teed is offline   Reply With Quote
Old 04-09-2013, 10:39 PM   #23
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Me too-went through 2 of those junkers then bought a ford dura spark dist to power an msd box-cured months of frustration! now I just say no to pertronix
Old 04-09-2013, 11:12 PM   #24
pmrphil
Liked 397 Times in 153 Posts
Chris - try swapping distributors and see if the problem goes away
Phil Molski
PMR Performance
S/C 1623
Old 04-10-2013, 08:40 PM   #25
christopher teed
changing distributors this weekend will let you guys know what happen...
Old 04-11-2013, 03:44 AM   #26
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
I have used the Pertronics conversion for years on my boat. It has worked perfect. I doubt that is your problem. Google the wiring for your unit online. I cant rember but I think you have to eliminate the ballast resistor. If the ballast resistor is still in the system that could be causing some issue. Also some ignitions used a resistor wire. Run new wiring to the coil and pertronics unit.
Mike Pearson 2485 SS
Old 04-11-2013, 08:38 AM   #27
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
The way you say your timing is jumping around,it sounds like ignition control/box problem.
I have used alot of pertronix on restoration projects have'nt had any problems,I use ignitor 3 has protection circuit and built in adjustable rev limiter,pertronix tech line has always been helpful when I have called,oddball installations, I would probaly give them a call.
I keep a hei w/wires so I can test and elimnate whole ign. system@ one time then have hei setup for msd so can determine box or dist.
Don't take for granted that any part can't be or go bad.
Mike Taylor 3601
Old 04-11-2013, 09:56 AM   #28
Run to Rund
Liked 56 Times in 29 Posts
Definitely check out the ignition as noted above. As a last resort, the carb to intake, or intake to head gaskets could be leaking vacuum.
Old 04-16-2013, 10:13 PM   #29
christopher teed
hope to change out distributor tommorrow...changed the advance springs in the current distributor from light to medium to heavy.....light is just simply to light and a great deal of difficulty cranking.heavy is ok ,but slow gettin to the desired timing mark from the dyno tuning ,tried the medium spring ,but when timing mark was set at the 40 degrees under a load,the intial timing at idle was just too low and the car ran crappy...hopefully the distributor change wiil do the trick..the 396 nova has 11;5;1 compression .via purestock drag rules... and a msd 6a.
Old 04-17-2013, 09:28 AM   #30
Mike Taylor 3601
try eliminate msd box had one bad on customers car,had trouble starting and timing did weird stuff,was trying to get running could'nt twist dist to get running enough to even get light on it.
Mike taylo
