Old 04-16-2013, 07:22 PM   #21
Mark Callanan
Liked 64 Times in 14 Posts
Default Re: Virgina
I am familiar with that hood and a bit ignorant of its importance.
What does it give one car over another?
D
Nothing...
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 04-16-2013, 07:26 PM   #22
Mark Callanan
Default Re: Virgina
Originally Posted by rod butcher View Post
I would guess that the cowl hood to be somewhat faster than the flat hood. Probably more so in SS where carb to hood clearance my be a problem with the flat hood. Has anyone A/B'd both hoods and want to share?
It isnt worth anything
Old 04-16-2013, 07:39 PM   #23
Mark Callanan
Default Re: Virgina
Originally Posted by Dan Fletcher View Post
I received my first ever letter from the tech dept after the World Finals regarding this matter. The quintesential SS/JA car is a '69 Camaro with a 255/350, and they've ALWAYS had cowl hoods. That, however, does not make it right.
I told Bruce I was sure one could "have" a cowl hood with that combo, but I'd research it. Turns out, not so much. The cowl hood (ZL2 option) was AVAILABLE on the Z/28 and SS models, and came included on the COPO and Pace Car. Well, you could not get the LM1 255/350 in any of those, so therefore, you could not pair a 255 with a cowl hood. Period. 300/350, yes, in both an SS and a Pace Car.
So, right is right, wrong is wrong, and the facts are the facts...
I also talked to Bruce about this issue
Bruce is a good guy that treated me with respect
As Dan Fletcher said right is right wrong is wrong
To bad all of Class racers didnt look at it the same way Dan does
We will change the hood at a cost of close to 1000.00
Old 04-16-2013, 08:29 PM   #24
Sean Gaffney
Sean Gaffney's Avatar
Liked 9 Times in 6 Posts
Default Re: Virgina
Originally Posted by mark callanan View Post
Nothing...
if there is nothing why is one rated at 315 and the other 317? If you want this issue to be about nothing have NHRA make both versions same HP right?
Sean Gaffney
SS/G & SS/H 1223
AA/S & A/S 1008
Sean Gaffney is offline   Reply With Quote
Old 04-16-2013, 08:36 PM   #25
Tony Janes
Default Re: Virgina
The 315 hp is a 1969 300/315 041 head engine. The hood is not a factor
Tony Janes 7941 STK, SS
Old 04-16-2013, 08:38 PM   #26
Mark Callanan
Default Re: Virgina
NHRA knows there is no value in the hood
If you have proof there is a value post your proof
Old 04-16-2013, 08:43 PM   #27
Sean Gaffney
Default Re: Virgina
Marc, that is my point exactly, why different HP ratings because of the hood you are campaigning? All I am saying is that wether you have a flat hood or a cowl hood it shouldn't matter and compromise the HP rating. It should be 315 or 317 just make it the same for all.
Sean Gaffney
SS/G & SS/H 1223
AA/S & A/S 1008
Old 04-16-2013, 09:04 PM   #28
Mark Callanan
Default Re: Virgina
Originally Posted by SS/GSI View Post
FYI, a cowl hood came standard on all 1969 302/Z28, Convertable Pace Cars, and 427/ZL1 Camaro's; however it was an option on the build sheet for every model in '69. You would have had to special order it but it was "available". The question then becomes does NHRA look at standard or optional trim on all cars for the HP guidelines, personally I dont care; however make your decision NHRA and stick with it.
Do you have any proof of this?
If you do it would really help me out?
Jsa3107@aol.com
Old 04-16-2013, 09:05 PM   #29
race watcher
Default Re: Virgina
It has been a while but I could run faster with the cowl hood with stock air cleaner base sealed to hood.
race watcher is offline   Reply With Quote
Old 04-16-2013, 10:09 PM   #30
Todd Hoven
Guest
Posts: n/a
Default Re: Virgina
If there is no difference why do people put them on instead of a stock hood? Because it looks cool? Being able to seal the carb to the hood is worth something, at least is was on my Firebird, and those scoops are in the wrong spot compared to a cowl hood on a Chevrolet. It doesnt cost a 1000.00 dollars to put a hood on one of those cars. You can by a brand new replacement for GM for under 300.00. Maybe this will go away, or people will have extra hoods for that new 300 Hp 350 or a big block project.
