Old 04-24-2013, 07:08 AM   #41
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: Schubek Lifters
Originally Posted by Greg Hill View Post
We run the Smith lifters in both of our motors and go through the traps at 7600-7800 and have had no trouble.
Same here.
Pedigo Perf is offline   Reply With Quote
Old 04-24-2013, 09:13 AM   #42
Dion Hildebrandt
Dion Hildebrandt's Avatar
Originally Posted by brent flynn View Post
Im guessing that the problems are coming from: too much ramp, too much RPM(Valve float) and not enough spring, is what causes the problems... Everything has a limit...even roller cams... i would like to hear from all the guys that arent having trouble with Smiths or even older Shubecks...These are guys that are probably running less than 7k through the traps...
I have the older Schubecks that came with my engine, I have had the engine for 6 or 7 years and I would guess there is maybe another 10 before that and no problems. I did break a rocker a few years ago, had everything magnafluxed and scoped , all that showed was two more cracked rockers, I cross the stripe at 72-7300 RPM's...
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-24-2013, 07:06 PM   #43
brent flynn
brent flynn's Avatar
Thanks Greg... Its good to hear Small block Chevy? I will be under 7k... around 6500-6700 with 190-200lbs on the seat, and roughly 400 over the nose... I should be fine, huh?
Old 04-24-2013, 07:24 PM   #44
Liked 1,907 Times in 427 Posts
We were turning 7800 with the 427 at Bowling Green this weekend, with 255 on the seat, and 600 open. We have too much open right now, I need to change springs.
What will hurt ceramic lifters is low spring pressure, resulting in a loss of valvetrain control. They do not like to bounce, whether it is on the ramp, or over the nose (commonly called "lofting") and that is where you'll see them break.
Old 04-26-2013, 05:29 PM   #45
brent flynn
In your opinion, for less than 7k, do you believe that 200seat/400-450open will work? Or should i shoot for a little more?
Old 04-26-2013, 06:00 PM   #46
Not knowing your combination as I do ours, I really can't say. I got a lot of help from fellow racers and fellow engine builders, as well as cam grinders to find what our combination likes. You should speak with your cam guy, and with people running similar combinations. Some engines that run at a lower RPM use more aggressive cam lobes, and still need as much spring pressure as higher RPM engines.
Old 04-26-2013, 09:18 PM   #47
brent flynn
THanks...Im gonna call Chris @ Comp and give him my combo( i have a comp cam) to see what he says about it...im sure he can help me... I appreciate the responses...
Old 04-26-2013, 10:37 PM   #48
Chris will give you good advice, he is one of the best guys to deal with for Stock and Super Stock cams and valvetrain.
Old 04-30-2013, 09:50 PM   #49
brent flynn
Any reason to run restrictors , with Smith Machine lifters?
Old 04-30-2013, 10:48 PM   #50
Todd Hoven
Guest
Posts: n/a
Yes to keep the oil in the pan and going to the mains and rods., especially with roller rockers. SOP with 400's in our deal
