View Poll Results: Double entering at National Opens
Yes .. entering 1 car in 2 categories the same day is fine 27 32.14%
No... one car per category is the way it should be. 57 67.86%
Voters: 84. You may not vote on this poll
Old 08-15-2007, 07:44 PM   #11
Incognito Gecko
Default Re: Double entering at National Opens
Originally Posted by John Kelley View Post
Just what happened there at Sears point ??
Let's put it this way, you did not see many hoods up in the staging lanes. And seeing a car run 2 seconds under the class index they put on their window decals. No scales or fuel check which is fine since there were no heads up races even if two class cars were paired in eliminations.
Incognito Gecko is offline   Reply With Quote
Old 08-17-2007, 08:58 AM   #12
TS310C
If there are no heads up races then it is basically a bracket race. What difference does it make at that point?
TS310C is offline   Reply With Quote
Old 08-17-2007, 10:20 PM   #13
Bob Orme
Default Re: What's The Beef???
Originally Posted by Rod Sintheblock View Post
If you go to a National Open and pay 2 entry fees it's only fair you would get 2 grade level points. Makes no difference weather you do it with 2-different cars or 1 car...2 entry fees is 2 grade points end of story.
You can't enter one car into two NHRA classes for grade points at any event. Pro or Super Pro or Sportsman or High School aren't NHRA grade point classes, they are track classes and you don't earn NHRA grade points for entering them.
The poll is rather confusing, and it wouldn't pertain only to National Open events. You can (where available) at Divisional events enter your car in your regular NHRA class, and also enter it into a bracket/gamblers event within the same event.
Bob Orme is offline   Reply With Quote
Old 08-18-2007, 11:27 AM   #14
Tony Janes
No car went 2 seconds under the index in Stock at the Sonoma National Open. A car is legal until proven illegal. No one recevied 2 grade points with one car. Some people entered but did not run in the elininator. Those are the facts
Tony Janes 7941 STK, SS
