Old 05-05-2013, 11:15 PM   #11
Default Re: 327/300 carb CFM
4 GC is 245...
AFB is 260 in a 65 Chevelle ..
Might be fun with a T200 ..but it's a lot cheaper to find out on a dyno...in the long run.
Old 05-06-2013, 09:33 AM   #12
Reed Granrt
Going in memory, the 327 with 250 hp had the 283 cylinder heads with a 1.75 int valve and a 1.5 exh ,small intake with a 4GC car and small exhaust pipe. The 300hp had the double hump heads with 1.94 intake valve with 1.5 exh with a larger intake manifold with the AFB with larger exhaust manifold. I started going thru some dyno sheets where I pulled the 250 intake and carb and installed a AFB and int. I think we picked up some hp but the heads were a restriction. Some of you guys will probably remember more than I do
reed
Reed Granrt is offline   Reply With Quote
Old 05-06-2013, 10:05 AM   #13
ss wannabee
Liked 7 Times in 7 Posts
Originally Posted by Greg Reimer 7376 View Post
That carb wasn't the only difference between the 62-65 250 and 300 horse 327. A good question was brought up, but I'd like to know what the CFM rating of the 4 Jet carb that the 220 and 250 horse small blocks was. The intake difference was notable, and the 461 head as opposed to the 520 head was another factor. Is the factored horsepower really that great a difference?
Not sure on the AFB carb...but checked into the 4GC's cfm rating many years ago...
Think I found about 475 cfm for the smaller early carb..(circa '57-'60?)...
Thought that the later carb was about 525...on the 220 and 250 hp engines...
Think there's one other 4GC as well...but that doesn't apply here....
Talking Chevrolet ONLY here...other GM's might be different....
ss wannabee is offline   Reply With Quote
Old 05-06-2013, 10:51 AM   #14
tony5022
tony5022's Avatar
Liked 10 Times in 2 Posts
My Corvette is able to run both combinations and we found that the AFB is 2 tenths faster than our WCFB with the right tune up. No dyno time just track tested.
Tony Hernandez
tony5022 is offline   Reply With Quote
Old 05-06-2013, 11:52 AM   #15
FED 387
Liked 335 Times in 182 Posts
Not sure of the carb specs that is being used with that particular combo but the smallest AFB is rated @400 CFM and they go up in size to 750 CFM while a WCFB is kinda rated @ 385 CFM for the smallest ones--- Found this a long time ago not sure how accurate it still is
AFB Carbs
CFM Venturi Diameter Bore Diameter
Primary Secondary Primary Secondary
400 1 1/8 1 1/4 1 7/16 1 7/16
500 1 3/16 1 1/4 1 7/16 1 11/16
575 1 1/4 1 9/16 1 9/16 1 11/16
625 1 3/16 1 9/16 1 7/16 1 11/16
750 1 7/16 1 9/16 1 11/16 1 11/16
ALL AVS CARBS
Primary & Secondary same size 750 CFM
Primary & Secondary different size 630 CFM
4GC CARBS
486 1 1/8 1 1/4 1 7/16 1 7/16
553 1 1/8 1 15/32 1 7/16 1 11/16
692 1 1/8 1 15/32 1 9/16 1 11/16
Old 05-06-2013, 04:25 PM   #16
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Except '65; the 327-250 used the same heads as the 327-300 in 1965. Been that way as long as I remember.
Old 05-06-2013, 05:15 PM   #17
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
That is correct..
In 64 and 65 the 327 were both rated at 250hp.
D
Old 05-11-2013, 08:58 AM   #18
Dan Lattimore
Liked 154 Times in 37 Posts
Smile Re: 327/300 carb CFM
Anybody know the CFM rating on that (AFB) carb ?
Mark, Cupp has answers to all those questions. Dyno comparisons, on track back to back, every trans. and rear gear combination you can think of. We have MIR again on Monday and he will be beating the tar out of the green bean again. ------ I'm going to quit parking beside him----------Danny
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 05-11-2013, 10:31 PM   #19
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 327/300 carb CFM
Seems to me that the 409 340 horse engine of 1963-65 had a BIG 4 jet on it. 394 Olds motors and the big Buicks got it as well. Heard of a fellow putting one on a 283-220 horse and getting a BIG quantum jump in horsepower with it. I had a 65 Impala SS convertible with a 409 340 horse and a 4 speed, but I ran an AFB on it,since they were easier to maintain. That car was a real road monster with the 3.31 gears, and it would tow about anything. Nothing like torque.
