Old 08-17-2007, 09:51 AM   #11
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Lt 1 ??
I just did a leakdown test on my engine as well as check some valve springs. Leakdown was pretty good and in-line with what I was told about these blocks. Springs had the same pressure as when I installed them but I am replacing them all with another brand. TOM T. ....I bought one of those K&N direct to t-body filters but find I will have to modify the water pump housing to get it on. I need to block off the top outlet at the t-stat housing and weld in a hose adapter on the side. Is that the way you got one on your stuff?
Rich Biebel
S/C 1479
Stock 147R
Old 08-17-2007, 10:04 AM   #12
Woodro Josey
Liked 3 Times in 1 Post
Default Re: Lt 1 ??
Rich, there is a K & N air filter that will bolt right on your Throttle Body, it is for a Marine application, Run's the same ET on or off, a very good piece.
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 08-17-2007, 11:00 AM   #13
bob shirley
Default Re: Lt 1 ??
wj,
do you have the partnumber?
bob shirley is offline   Reply With Quote
Old 08-17-2007, 12:11 PM   #14
Woodro Josey
Default Re: Lt 1 ??
Yes Sir,,,,,,,59-5020 K & N Kinda hard to find in a parts store!
Old 08-17-2007, 12:19 PM   #15
Rich Biebel
Default Re: Lt 1 ??
Woodro...I got one like we talked about but it hits the t-stat housing. It is somewhat oblong shaped and the flange goes directly on the t-body, perfect fit. It will not go on with the t-stat housing in place as the lower part of the filter hits that housing. The one I got is KN part # 59-5050. It's listed as a marine spark arrestor. If there is one that fits with the t-stat housing in place it's not the one I have.
Rich Biebel
S/C 1479
Stock 147R
Old 08-17-2007, 01:07 PM   #16
Woodro Josey
Default Re: Lt 1 ??
Rich the 5020 rubs the Thermostat housing but not a problem, it has an indention in the Filter, fits very good!
Old 08-17-2007, 01:14 PM   #17
Woodro Josey
Default Re: Lt 1 ??
Rich go to www.knfilters.com and go to search and type in the number and they have a good view of it there!
Old 08-17-2007, 01:18 PM   #18
Rich Biebel
Default Re: Lt 1 ??
Woodro, I saw a race car with a K&N like the one I got a couple years ago and that's what led me to buy the one I have. It is tapered front to back. I think I can weld in a hose adapter on the side for the rad. hose. There was an outlet there probably for a heater hose fitting I'd guess. I did see the 5020 but remebered that tapered one I saw on a car and ordered something that had that tapered shape.
Rich Biebel
S/C 1479
Stock 147R
