Old 05-21-2013, 06:34 PM   #2391
rhinodaert
Liked 4 Times in 3 Posts
I will see you in Farmington as I am bringing one of the Sox and Martin 68 Barracudas. If anyone is interested it is for sale for $250K. It was originally one of the Billy Stepp cars and owned a couple of times by S&M.
Old 05-21-2013, 06:42 PM   #2392
rhinodaert
According to the Mecum site, this Dart bid to $125,000 and "The Bid Goes On"....it has a 3 speed?...I have a feeling there might be more ???s
I was at Mecum and that car is the Eddie Smith car that was bought at Mr, Norms then sold to Max Hurley. I believe Max raced it with a 3-speed. I know that Reed Koeppe in Nebraska found it then sold it after I bought the Max Hurley 71 Super Stock Demon that I sold to buy my Hemi Dart. Also at Mecum the first Billy Stepp car bid to 100K and did not meet reserve.
Old 05-22-2013, 10:19 AM   #2393
Liteweight
Liteweight's Avatar
Liked 31 Times in 19 Posts
Originally Posted by bigsixman View Post
Looks good Daryl, are you going to Farmington, MN for the Mopar Show?
hey Craig
I'm leaving for that show Thursday May 28, & will be driving by Grand Forks around noon. What say you we meet for lunch at a good burger joint. Is there a Hardee's in Forks anymore? we don't have any of those joints up here in Manitoba & I try to get at least one double cheese & curly fries in per US visit.
Hey, I might even be convinced to unload my car & take a certain good ol boy Bowtie guy for a hoot & holler ride if the weather & roads are good. You never know, I might be able to convince you to come over to the dark side. It'll be a ride you won't soon forget, me's thinkin.
liteweight
ps Don's riding shotgun with me for the weekend.
Old 05-22-2013, 10:56 AM   #2394
bigsixman
Liked 2 Times in 2 Posts
Daryl: Is it Tuesday May 28th or Thursday May 30th that you are coming through GFKS? On Tuesday the 28th I have a county board meeting, but on Thursday May 30th I have clear day with no meetings. The Hardees on Columbia Road is still open and I would enjoy a lunch with you and Don. I think we can find a place to unload that dart too! Next year I hope my 67 camaro project car will be done and I will bring it up to the Garden City Mall show in Wpg and I will return the favor, I will furnish the Depends!!! Lets stay in touch on your travel times.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
Old 05-22-2013, 11:06 AM   #2395
Liteweight
Liteweight's Avatar
Craig
my bad, too many late nights. Yup, your right it's Thursday May 30. Should be leaving 8:00-9:00 am & depending on the border patrol. We'll be in Forks by noon. Bring some pictures of that car.
liteweight
Old 05-22-2013, 02:40 PM   #2396
Liteweight
Liteweight's Avatar
Bob
So you want to install a Hemi in a A body using factory mounts?????. Your a brave man Hope you have alot of patience, specially if your using box headers (Hooker/TTI etc.). If you want to use an external oil pickup system, stay with a single line, because a dual line is ALMOST not doable without doing alot of cutting OR fabricating of mounts, & creating a new pickup port in the pump body because the "as delivered" ports will now allow for that second line.
As your probably aware Hurst/Chrysler utized the welded steel mounts on the K member from Hemi B Bodies to build the original Hemi A cars.The rubber insulators were also used.
The tubes they used were Hooker 2" & were delivered with a street hemi pan. This combination worked as is but did not allow for the oiling required for a high winding Hemi. So, the cutting started on both the drivers side mount & steering box mount.
Now getting back on track to your install, the easiest will no doubt be an engine plate with a torque restrictor to limit fore & aft. movement.This will allow for dual external oiling & lots of header clearance
If your interested in this next option, pm me & I'll give you the name/number of a buddy who fabricates 2 different Hemi A body K members as complete bolt in kits utilizing original style mounts, original K members & suspension . The first one he designed a few years back that locates the engine a little lower than stock, which allows for much needed trans tunnel/ header clearance. This K member will accomodate box headers. You'll have to ask him about 2 1/8" tho. I believe it'll only work with a single feed external oil system.
The other K member he has available is a direct replacement of the originals, location wise. I know that because he borrowed my original to build his jig.
My Hemi install is a little unique as I'm using an unmodified original style K member with custom built headers, custom fabbed engine mount made from DOM 1 3/4" tubing & a modified Milodon dual oiling system. MANY, MANY hours were spent making this work & all clearances for everything in that area are minimal. 1/16" is the difference of something fitting or interfering.
This is the passenger side mount
This is the drivers side mount
If you closely you can see the new oil location at the bottom of the pump. The original 2 rear pickup locations remain plugged
This is the almost ready to install assembly. Tubes are custom made . 2 1/8" primaries, 4" collectors. Passenger side is 2 piece, Drivers side is 5 piece. I need to remove both torsion bars, both tie rod assemblies, center link, have no starter or even the drain plg in the block to get them in. I can't even have the header gasket glued to the head for install, because the thickness of that gasket won't allow #1 tube to go in, even with the engine lifted. The gasket needs to be slipped in after the headers installed.
have I scared you yet? They're not all this tight. I sold Dave McDade an original unmodified Hemi A Body K member & he installed it with the motor attached from the bottom. He dropped the body over the assembly. Valve covers were off tho. I don't believe he has an external oil system & I think his tubes are 2". Feel free to ask whatever you need to get that elfunt installed, & I'll do what I can to help you out.
liteweight
Old 05-22-2013, 09:07 PM   #2397
Skypower
Skypower's Avatar
Thanks Daryl:
That sure looks like a nice setup you have there.
My motor is a pump gas motor with only 580 lift cam and 10:1 compression, built to be a daily driver if I so choose, 550 hp 516 tq. Internal oiling and stock valve train, with stock type chrome valve covers. I am doing the shock tower mod to give me a little more room if I decide to change heads and valve train. I'm pretty sure I will be putting it in from the bottom as I have spoken to quite a few who have done it that way and say its a lot easier. The pics you posted help a lot, thanks. I will be taking my car to my chassis guy in a couple weeks once I make a decision on what bell housing to use, my car is a stick car.
I guess one question, what torsion bars are running.
Is your k member guys name Denny?
69 Cuda / with a 66 426 Hemi, 4 speed, Dana 4.56
68 Cuda getting ready to go on the rotisserie.
Skypower is offline   Reply With Quote
Old 05-24-2013, 12:20 PM   #2398
Liteweight
Liteweight's Avatar
Originally Posted by Skypower View Post
Thanks Daryl:
Those kind of numbers will more than knock your socks off in that car & be street friendly too.. You'll enjoy it, specially rowin' gears doing it..
You won't regret doing the shock tower mod.
You'll probably want to put a scattershield on it for your toes sake, a 2 piece with access from the bottom is preferable. Depending on engine location, will dictate whether you"ll have to modify the firewall to floorpan flange & you may want to drill holes in the firewall for the top 2 bellhousing retaining bolts, then install those snap in plugs.
I'm currently running the small block bars in my car. I tried the 6 cyl. ones, but didn't like them because of excessive front end rise, & they were wound too tight for my comfort, street driving it.
My K member connection is Al in WI.
liteweight
Old 05-24-2013, 12:38 PM   #2399
Liteweight
Liteweight's Avatar
After many,many hours of cheet & abuse that it has provided for me, it's finally alive.
When it barked to life, the hair on my arms stood at attention. To describe what it sounds like is best done through a quotation my buddy yelled @ me last night while it was warming up. "That ain't no 10 sec. motor."
I just smiled
I tend to agree with him.
I love it when a plan comes together
Giddyup............................
liteweight
ps. the build tour will continue.
Old 05-24-2013, 05:37 PM   #2400
I just smiled
liteweight
Ok "Hannibal",requesting audio/video asap.
Share the experience with the rest of us.
I have a mop and bucket to clean up the expected drool.
