Old 06-05-2013, 02:38 PM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Pure Stock Challange - Ohio May 2014
NHRA had pure stock before IHRA existed. They were pure stock. Didn't last long. No much participation then either.
Dan, I don't have a stocker. Have no desire to drive what I do have on the street.
It used to be a nine second NA street car that still got close to 20 mpg. :-)
LOL.....
YEAH remember it well, ran Pure Stock in 19(oh)73
Then the Blueprinted cams replaced that because of creative cheating.
Which is basically what we have today as Pure Stock..
But you make a point.
Heck the new Mustangs can run a 9 second ET and can get 20mpg.
Just need a Supercharger..
Dan
Old 06-05-2013, 05:48 PM   #12
Ed Wright
Ed Wright's Avatar
I didn't need a supercharger.
Ed Wright 4156 SS/JA
Old 06-05-2013, 06:25 PM   #13
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Impressive.
Just curious: What RPM did that 9 second N/A engine idle at ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 06-05-2013, 07:14 PM   #14
Ed Wright
Ed Wright's Avatar
1200.
Still hanging on an engine stand out in the shop. Want to buy it?
Old 06-05-2013, 07:37 PM   #15
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Pure Stock Challange - Ohio May 2014
Originally Posted by Michael Beard View Post
IHRA Pure Stock rules have been largely unchanged for many years.
Aftermarket camshafts are permitted, but "must check on or under factory specs for lift, duration, and overlap." Transmissions must be stock, unaltered, except for shift kit. Aftermarket converters are allowed.
IHRA Rulebook is available online, see Pure Stock on page 47-48: http://www.mydigitalpublication.com/...tion/?i=136499
donc - thanks for your support! Will send you a PM.
How many tech guys really know HOW to check duration and overlap......LOL. Not only that but the tech specs on most newer cars do NOT even list duration and overlap specs or valve spring pressures.
Old 06-05-2013, 08:06 PM   #16
Ed Wright
Ed Wright's Avatar
Red Anderson made some slick tools for that. He was quite the machinist. He checked mine several times. Those Lunati and General Kinetics "cheater cams" we ran back then looked like the roller cams we run now: lobes were flat across the top. LOL
Take away the light pistons and we had present day "pure stock" engines, it sounds like.
Old 06-05-2013, 09:48 PM   #17
X-TECH MAN
Banned
Thumbs up Re: Pure Stock Challange - Ohio May 2014
I met Red when I first worked for the NHRA. It WAS a good organation back in the early 70's for those who are to young to know or remember. I still have my 2 piece degree wheel I got from Red for checking cams and a cpl. of other things. He was a sharp man. 2 other greats were Marty Barrett and Greg X. They were good to me and showed me a lot.
Old 06-05-2013, 10:06 PM   #18
Ed Wright
Ed Wright's Avatar
That two piece, adjustable degree wheel was a slick deal. His little magnetic based, folding pointer was neat too.
First time Red tore me down for a record (The new Dallas track in Lewisville) he wouldn't let Carroll Caudle watch him check the cam. Carroll had machined my block, and did the "trick" (at the time) valve job, and built a lot of engines. Carroll helped me take it apart. I think Red thought Carroll did the whole engine. Made him go stand about 50' away while he checked everything. LOL
Guess he didn't want Carroll figuring how to slip something by. Had me scared to death! LOL
I could have threaded a running sewing machine.
After that tear downs seemed a lot more informal. Red would actually joke around during checking it. Think some of it was to make me squirm. He got to be a friend.
Old 06-05-2013, 11:32 PM   #19
Dan Fahey
Dan Fahey's Avatar
I remember the McElroy Grind which got me bounced at Atlanta.
It was square topped to.
My Bullet Cam is mild in comparison yet requires Stock Spring pressures.
So you cannot go to wild.
D
Old 06-06-2013, 08:04 AM   #20
Ed Wright
Ed Wright's Avatar
We had to run stock spring pressure too. General Kinetics cam was my fastest. Spring eater. GM springs = two races. TRW springs = three races, sometimes four. My engine ('56 Chevy) was the 2-4bl 225 hp Corvette engine, solid lifters. The GK cam used .003" lash. Last pass of the day, check the lash before loading up to verify everything was up to temp.
