Old 06-10-2013, 10:07 PM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation 5/04/13 SRAC Meeting Notes From Mike Crutchfield
Please see the notes from the last SRAC meeting 5/4/13
Review Last Call --
1. Aftermarket Seats permitted – Must be identical –Resolved Jan 15 Rule Revision – Question came up about when letters became standard procedure for fixing things versus verbal warning. Answer – Record keeping and physical proof of warning
2. Cylinder Heads – Valve Cover Bolt holes must remain unaltered and in original location – Resolved by wording pertaining to 2014 NHRA Rulebook.
3. .080 cylinder overbore max. & Aftermarket NHRA-accepted Crankshaft permitted (must retain OEM Configuration – billet, knife edging, etc. prohibited) – Recommend issuing wording prohibiting Bull-nosing, gundrilling, etc. In Stock Only -- Definition to be in 2014 NHRA Rulebook
Items of discussion –
1. Live Timing – Request to delay all Live Timing Results until after the entire class has made their run, especially in the Sportsman Classes. This will help to do away with delays in waiting on cars to come to staging during Eliminations. – Request to be forwarded to Josh Peterson
2. Penalties – Recommend to lower maximum fines for Sportsman racers for Technical Violations (Cubic Inch limits, head CC’s, weight infractions, etc.) to $2500 Max. Reasoning is that $5000 for a Sportsman racer is too much in these economic times and it’s making racers question whether NHRA wants them to participate.
3. Penalty Publication – Recommend that all penalties, when published, should be located in the same spot no matter whom or what the infraction is. Don’t hide one infraction and then make another infraction front page news.
4. Sportsman Run Schedule – Englishtown run schedule was discussed. Running only 2 categories back to back was not the ideal situation. The schedule was changed to this based off recommendations to keep minimal time between runs for competitors. Discussion resulted in Bob Lang and Dave Mohn advising schedule changes to avoid the back to back situations – possibly Stock or Super Stock, Super Street or Super Gas, Super Comp, then back to Stock/Super Stock. Vary the wheelbases of the cars to assist maintaining starting line.
5. Super Stock Bumpers – Miscommunication brought a rumor about notching Super Stock bumpers. This is meant for only base Super Stock cars and not GT cars. Jeff Teuton brought up the fact that the new cars (Drag Pak Challengers, COPO Camaros, and Cobra Jet Mustangs) will need to do something in Super Stock to allow wheelie bar travel.
6. Track Prep – The Super Category SRAC had a conference Call about this subject. In years past we would drag and then spray. Racers were concerned that there was too much spray on the track and little dry time for the spray to cure. At the Maple Grove Event, we switched by spraying and then dragging – this seemed to provide a consistent track surface. We did the same thing at Englishtown National Event. Down track went all weekend long. The starting line had inconsistencies due in part to excessive track temperatures and wheelbases of vehicles to start the weekend. National Event track prep is the same daily – Vacuum the track, wash the track, spray the track, and drag the track. At every National Event there is 3-5 hours of downtime for track prep not including the morning ritual or end of day scraping.
7. National Event Stacking Policy – SRAC requests doing away with this policy as it adds more expense to the tracks that have to chase people away and it also increases the expens for racers travelling from one event to the next.
8. Double Events – Most of the SRAC like the idea of towing once and running 2 races. Double events would not be possible in D-1 or D-3 all agreed.
9. Showroom Cars in Class Guide – SRAC recommends getting Manufacturers to add showroom available cars to the class guide to allow more people the opportunity to race newer cars as older cars are getting harder to find parts for. Pat Cvengros commented that getting Specs from the Manufacturers is very difficult.
10. The subject of Finishing Sportsman on Saturday – Sponsored racers are not in favor of finishing on Saturday due to the possibility of no tv time for their sponsors. Englishtown schedule of running Semi’s and Finals on Sunday was discussed most liked the idea.
Thanks
Mike Crutchfield
Division 2 SRAC Member5
Old 06-10-2013, 10:23 PM   #2
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Default Re: 5/04/13 SRAC Meeting Notes From Mike Crutchfield
Thank you - very help communication
Ron
Old 06-10-2013, 11:22 PM   #3
SS3718
Liked 27 Times in 14 Posts
On item #2: Penalties
Are the penalties outlined somewhere in the rule book or on the website? Or the sole discretion of NHRA? It seems to be something that's new this year. I apologize in advance if this is a dumb question!
Mr. Crutchfield, thanks for the update!
Nick Morris
SS3718 is offline   Reply With Quote
Old 06-11-2013, 03:58 PM   #4
Tom Moock
Liked 10 Times in 6 Posts
Mr. Crutchfield, could you post the fines for cc heads, cub in.,lift on cam, crankshaft,piston and rod weight and other things I forgot, I don't build my own motor's,so I need to known what the fines are because maybe I can't afford to race NHRA with $5000.00 fines. Racer mite think twice about setting record's and going to national events. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-11-2013, 06:41 PM   #5
Jeff Teuton
Liked 325 Times in 50 Posts
We are working on the fine amounts and the different kinds of violation; safety, behavior, technical, etc. More as it unfolds.
Jeff Teuton 4022 STK
Old 06-12-2013, 12:59 AM   #6
SS Engine Guy
Is #5 worded incorrectly or are ss/gt cars not allowed to be notched and regular ss are? If you are allowed bars I would think it would be allowed to be notched a minimum to keep from tearing up panels on stock/ ss/ and ss/gt. I have had several best engineered awards over the years on all three types and all were neatly notched for clearance. Is this something new because no one in hundreds of tech or tear downs has ever mentioned it.
SS Engine Guy is offline   Reply With Quote
Old 06-12-2013, 02:28 AM   #7
jmantle
Liked 172 Times in 81 Posts
Stock /SS are not allowed to notch anything as it now stands, GT cars are.
Jim Mantle div 6 SRAC
jmantle is offline   Reply With Quote
Old 06-12-2013, 07:11 AM   #8
Dick Butler
Liked 32 Times in 19 Posts
.80 over bore?
Old 06-12-2013, 10:15 AM   #9
Tony Janes
Dick you have not read the 2013 rules.
Tony Janes 7941 STK, SS
Old 06-12-2013, 11:18 AM   #10
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The original 2013 Rules, as written, had a typographical error that said .80 overbore. It was corrected in the first update to the proper value .080.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
