Old 06-09-2013, 09:48 PM   #1
duke66
Default mounting AFCO rears
My Son's 68 Camaro, basically a F/SA, has all Caltrac rear set up, how does everyone mount a large body shock to the lower spring plate? Shocks are in the stock positions. The body of the shock hits the plate.
duke66 is offline   Reply With Quote
Old 06-10-2013, 11:58 PM   #2
sixty8
sixty8's Avatar
Default Re: mounting AFCO rears
This is an AFCO 3870R mounted in a 68 Camaro with Caltracs and split-mono springs. I used a bolt with spacers to get it away from the axle tube. I am also interested in how others have mounted theirs.
sixty8 is offline   Reply With Quote
Old 06-12-2013, 08:52 AM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
How much shock travel do you have for rebound/extension?
Clark
Old 06-12-2013, 09:02 PM   #4
sixty8
sixty8's Avatar
3" compression 4" extension @ ride height.
Old 06-12-2013, 09:14 PM   #5
Dragsinger
Liked 99 Times in 60 Posts
AFCO shocks can be mounted up-side-down. Look at the room available to see if doing that is an option.
Larry Woodfin 471W
Old 06-13-2013, 01:15 PM   #6
cad
cad's Avatar
Thanks...a stock camaro requires a stud at the top and the inner wheel house to trunk pan is too narrow for mounting upside down.
