Old 06-17-2013, 07:31 PM   #1
Shawn S.Kvaas
Default C 12 side note
The c12 fuel I ran in my car this weekend at mission was from last July when I bought it for Woodburn. I had half a tank sitting in the car since then, and 3 plastic 5 gallon jugs sitting under a tree in my back yard out in the elements. all this fuel tested perfectly every time.
Shawn S.Kvaas is offline   Reply With Quote
Old 06-17-2013, 08:42 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: C 12 side note
I ran the first race this year on left-from-last-year C11. It had been in the plastic jugs in my trailer over the winter. Checked perfectly, "right in the middle" they told me. Never a problem with C11.
Ed Wright 4156 SS/JA
Old 06-17-2013, 10:03 PM   #3
Darrin Christen
Darrin Christen's Avatar
Only problem with C-11 is the price! Lower octane, yet cost more than some of the higher octane fuels.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 06-18-2013, 08:57 AM   #4
Ed Wright
Ed Wright's Avatar
Darren, in my car it's a tad faster on C11 after adding about 5% WOT air/fuel. More octane than you need costs a little power. Of course, in slow down mode that doesn't matter. :-)
Old 06-18-2013, 09:49 AM   #5
KRatcliff
Liked 534 Times in 143 Posts
Isn't C-11 a little quicker burn rate than C-12? No?
Lower octane doesn't hurt as long as you are not detonating. A quicker burn rate is....well....quicker.
I can see how C12 would check ok in Mission. I think it has a harder time in the heat of our area if not properly stored. And sometimes it will be marginal right out of the drum.
This also may be due to their testing equipment at the tracks.
KRatcliff is offline   Reply With Quote
Old 06-18-2013, 10:05 AM   #6
Dave Ley
Liked 241 Times in 44 Posts
Send a message via AIM to Dave Ley
C11 has a much lower specific gravity than C12. The lower the specific gravity the faster it burns. Faster burning means more power. You aren't paying for octane you are paying for the properties that make it have a lower specific gravity.
Dave Ley
Dave Ley is offline   Reply With Quote
Old 06-18-2013, 10:40 AM   #7
Darrin Christen
Thanks for the explanations guys.
Specific gravity
C-11 .710 @ 60* F
C-12 .717
C-14 .696
C-16 .735
C-25 .695
At No Problem Raceway for the D4 race C-11 and C-16 were $16.00 per gal. and C-14 was $14 per gallon. Sorry for getting off the original topic. I do run C-11 with no problems at fuel check as of yet, but I'm new to this super stock stuff. Maybe I should try some C-25, I could use all the help I can get.
Old 06-18-2013, 10:52 AM   #8
Crew Chief
Liked 10 Times in 6 Posts
How is it that most everyone passes and only a few fail? If the testing equipment was bad wouldn't everyone fail?
Crew Chief is offline   Reply With Quote
Old 06-18-2013, 11:06 AM   #9
KRatcliff
This is based on my experience at the fuel check in Div 4. I use C11 in my stocker and C12 when I drive our Calais super stocker. Without question C12 was the one that would come up bad from the others being checked. And many of the comments would be "I just got it off the truck.."
The testing equipment looks like something from the 80's. Maybe it isn't that critical, but I am not the first to question how up to date their equipment is.
Old 06-18-2013, 11:14 AM   #10
Jody Lang
Liked 92 Times in 29 Posts
The real problem is the way the testing process is set up. To be clear the parameters or window that the fuel is suppose to test within.
When I've been close to failing fuel check it's always been on the low side. A few years back at Sonoma many of us were close to failing or failing.
I went and bought a fresh 5 out of a new drum. They tested it for me and said it was perfect, right in the middle. Why if when we fail it's always on the low side, but when the fuel is fresh it only starts out life in the middle?
Shouldn't it start out life at the top of the scale???
Jody Lang is offline   Reply With Quote
