Old 06-19-2013, 07:05 AM   #21
Liked 1,922 Times in 432 Posts
Default Re: Wheelie Bars are not needed for Safety on Stockers!
Originally Posted by Notch1320 View Post
1.18 -1.21 on the car I crew on. 3500lbs...........Leaf Springs........Bolt on replacement style front clip. 52-53% on the nose.
Yes, these cars are different from Stockers.........But it can be done safely without sissy sticks.
No, it can't. I'd take them off if I could.
Old 06-19-2013, 07:23 AM   #22
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Yes, these cars are different from Stockers.........But it can be done safely without sissy sticks.[/QUOTE]
And what you are missing is that if you'd put slicks on instead of the drag radials, cranked the rpm up on the launch and made some serious starting line power (as apposed to launching at a low rpm, or low timing to reduce power) a setup that would most likely run quicker than the 5.00 you've posted, you'd need wheelie bars. You may be the quickest in your class, that is limited in tire spec, but if there was no tire spec, you'd hit it harder out of the hole like we do and scape your bumper on good tracks, like we can.
My stocker has road a 300 foot wheel stand right verticle, my super stock has hit the bars so hard the rear wheels came of the ground. my 1967 1000hp super charged chevelle pulls 1.5' wheelies, no bars.
...i think yellow bullet has forum where you may make more sense!
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 06-19-2013, 07:59 AM   #23
Bruce Noland
Liked 444 Times in 145 Posts
Alan,
Notch is switching things around a bit. The toaster car turns a 1.28 sixty foot while running a 3.50 rear gear and a 1.80 first gear in a glide. And uses coil over ladder bars and it still appears to be turning the tires. Now he wants to talk about a car he is crewing. He's just out here jacking around. Nothing he has posted has anything to do with Stockers.
Bruce Noland 1788 STK
Old 06-19-2013, 08:15 AM   #24
boostedf22c
boostedf22c's Avatar
You can't compare a small tire, no wheelie bar, power adder car to a Stocker or Superstocker. Two completely different cars with two completely different setups.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 06-19-2013, 08:35 AM   #25
Bill Harris
Liked 26 Times in 13 Posts
If NHRA expects stockers to tune with the suspension then they shouldn't prohibit travel limiters on the front end. Don't say to tune with suspension and then take away a major tuning capability, dumb-asses.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 06-19-2013, 09:58 AM   #26
Bruce Noland
It's a sad commentary. Under Compton the tech department has been reduced to picking on petty things like wheelie bar notches.
Old 06-19-2013, 10:33 AM   #27
sammy pizzolato
Liked 56 Times in 13 Posts
Send a message via AIM to sammy pizzolato
we need another wally parks.we need people with drag racing know how not ones that never raced.people like lynwood dupre,steve gibbs,to say the least.
sammy pizzolato is offline   Reply With Quote
Old 06-19-2013, 01:22 PM   #28
Notch1320
This original discussion was about "Stockers" and wheelie bars correct? I'm not sure how SS cars are now in the mix here??? My posts were directed at the "1000HP to 1200HP" car comment. Yes, what the 8.5 guys are doing is WAY different, but a Stock Eliminator car CAN Safely run without wheelie bars if NHRA were to instruct you all to remove them. I'm not trying to stir the pot here, just putting in my 2 cents. Carry on.....
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 06-19-2013, 02:26 PM   #29
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
The key word missing from the vocabulary of NHRA, is LOGIC!!! Without this, all discussions will seem challenged by incompetence.
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 06-19-2013, 02:33 PM   #30
TOSTO RACING
TOSTO RACING's Avatar
Liked 663 Times in 187 Posts
I won't run my car without them !
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
