#41 |
Liked 345 Times in 149 Posts
That would be an incorrect assumption.
#42 |
Don't stir the pot Todd! The elders don't like it.
Shawn Allsup K/S 718 |
#43 | |
"THEY" are running them because they are allowed to. The cars would be fast even if they weren't allowed to run the bars.
#44 |
Liked 547 Times in 214 Posts
If you slow down the front end travel on a small tired Stocker you always run the risk of spinning the tires.
So you run the front end loose and if you have a car that is prone to doing wheelstands in good air and traction conditions you might find your up too high on the launch......If you lift you will probably cause some damage.....oil pan.....front end.....If you don't you could unload one tire when the rear sheet metal contacts the ground and wind up hitting something........like the guardrail or even the tree or the car in the other lane.... You have a 3 speed trans with a fairly steep rear gear and that makes a very low starting line ratio....and anyone whoever raced a Stocker knows the biggest ET gains are in the first 100 feet or so..... If all this wasn't true all the cars that had powerglides and are now allowed 3 speeds would not have bothered to make the change.,.... I drove my old car a couple years ago when the present owner offered it to me for a couple races. It was doing some pretty high wheelies......I asked for the wheelie bars and put them on as I really did not want to hurt the car. It did a very high wheelie at the Dutch with the bars on and might have been a problem without them on for that run..... Late model F-bodied Stockers are well known for doing big wheelstands and I recall one set of pictures form E-Town of a car that popped the hatch open when the rear bodywork dragged the ground....NO BARS....and it was pretty sideways when it came down...... I think it is rediculous to say a high class Stocker can be adjusted so it does not need bars.....If it is a wheelsatnd prone car like many it needs the bars.....and it is for safety.... Oh and the present owner of the car I was driving told me the reason he BLEW the Tires off at the E-Town Nationals in his other car was because he went a little to tight on the front end.....and that the only way to insure the car would hook was to do exactly what I told him two years ago .....leave the front end loose and use the bars......
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 06-19-2013 at 07:40 PM. |
#45 |
Liked 444 Times in 145 Posts
Fast is relative. You are really very quick with the assumptions. They run the bars because they make the cars safer not because they are allowed.
Bruce Noland 1788 STK |
#46 | |
My own car is a heads up, N/A car. Car weighs 2960 with driver and has 54% of the weight on the nose. It's got a conventional headed BBC that makes between 1100 and 1200 hp. The converter flashes to 7000 rpm, 4.57 rear gear on a 275/60 DOT drag radial tire which is 28" tall and has 10" of tread. The car runs 5.0's at 137 mph and has 60'd a best of 1.129. I'm just sharing this as there has been some misinformation when the heads up stuff was brought up. I have used bars for several years, but when I started running this new class they are illegal, so I was forced to figure out how to run the car without them and keep the front end down. No it's not easy and if you make a bad tuning call it will go up (much quicker and more violent than a stocker). Now, last I knew stockers weren't allowed travel limiters, but S/S was correct? I'll also concede that lower HP cars need some weight transfer to get up on the tire where a higher HP car can plant it with power. I will say this, I'm glad I no longer use the bars. They were a PITA as far as I'm concerned. It also makes you work harder to find the right setup for the days track/weather conditions as well as the tuneup you have in the car. That to me is a fun challenge even if I fail to get it right. I would ask this. If bars were suddenly made illegal on stockers, would those who run just park their cars, or would you buckle down and figure out a way to make it work without them? Stock and S/S are great classes, some of my favorites by far. I kinda treat mine as if I was running S/S on small tires & stock suspension as far as running as hard as possible to the 60 & 330. And I do understand you can't easily compare low & high HP cars when it comes to some of this stuff. Last edited by Todd Geisler; 06-19-2013 at 07:32 PM. |
#47 |
Liked 662 Times in 187 Posts
If wheellie bars were illegal in stock i'd buy some 205/70/15 radials,a powerglide, and run the dog squat nationals! And go 10.90's and 310 mph lol!
I really can't believe these guys are worried about a notch in the valance panel with all the other stuff that is legal in stock lol. That's my .08 cents worth lol!
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA Last edited by TOSTO RACING; 06-19-2013 at 07:40 PM. |
#48 | |
#49 |
I don't even have a notch in the bumper and just think its silly! Some cars need a little notch to make the bars work right in my opinion.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#50 | |
So your question of either parking the cars or changing them is based on something that will never happen and offers a false premise. No, I don't think you are trying to be tricky. But, the executives at nhra would never ever take away a piece of safety equipment that could result in serious legal exposure for injury or death. Remember this safety equipment was openly supported and approved by nhra personel and then published in the Dragster when accepted.. Another point to remember is that many of us build and work on our own cars and for some the wheelie bars offer a greater amount of protection. The legal folks at nhra know this as well.
