#311 | |
#312 |
Liked 99 Times in 21 Posts
Billy, I done a little digging and it looks like the stick has the 2150 motorcraft and the auto has the variable ventura 2700. Cant find a ventura size anywhere. Did find a CFM chart
.98=190cfm, 1.01=240cfm, 1.02=245cfm, 1.08=287cfm, 1.14=300cfm, 1.21=351cfm, 1.21=351cfm, 1.23=356cfm, 1.33=424cfm, for the 2100 and 2150 carbs. I am ASSumimg the variable ventura is only one size, can't find much on it other than it came on engines from 171ci to 351ci. it might be pretty big if the engine will pull enough to open the vents fully. Don Jackson |
#313 |
Liked 783 Times in 195 Posts
#314 | |
Liked 5,142 Times in 1,963 Posts
I never paid much attention to the 60 deg. V6..but knowing what we know now, it might be worth a second look. Near as I can tell ,it's a 2150 with a 1.08 venturi...Same as the 77 302! A little more cam lift, and about the same compression.. The short stroke hurts the low end torque ,but it should rev pretty high with that carb on a small c.i. engine. Cam cores might be a problem. It seems that there WAS a C4 offered with the Taunus bell housing pattern, which you'll need...(not a C3) There are some minor differences in the various years. I haven't looked that close Your job! I see it as an easy .5 under deal, if you can find .030 over OEM pistons. More than that, if you want to invest in a 7" converter.
#315 |
Liked 54 Times in 18 Posts
Heres a tip on the clever engine design. Lifters must go in before heads go on or they wont go in at all. Yes, Im serious ! A lot of people learned that one the hard way
#316 | |
You don't need a Pinto wagon though..In fact, you don't even need a Pinto. Mustang II is the way to go. If all else fails, go with a 302. *Actually, you can use a Fox body 79 too..Still with 2150 1.08 carb
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 06-20-2013 at 10:59 PM. |
#317 |
#318 | |
BTW, I can remember seeing Rockwells car at Island leaving on the bumper and breaking axles! talk about Stockers needing wheelie bars!
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 06-21-2013 at 09:24 AM. Reason: addition |
#319 |
Dime Rocket Alert! http://www.classracer.com/classforum...ad.php?t=48226
I don't know Tom or Sean but I have seen the car around and think that this puppy could be faster than stink. AND it can fit 5 different classes with an intake change.
#320 |
Liked 460 Times in 91 Posts
![]() The three cars here are still good "Dime Rockets"
Bob Bender 144 O/SA 2010-2012 National Record Holder |
