Old 06-24-2013, 06:58 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Help with Accel Calmap 6.0
Recently acquired stocker has an Accel Calmap 6.0 Engine Management System.
The current set up is open loop, has separate O2 sensor system, and EGT's.
I have a tune-up matrix that came with the car that allows fuel map changes based on % up and down from a base setting.
I would like to talk to someone who has experience with this system to answer a few ( well, maybe more than a few) questions on how to effectively utilize this unit.
I realize there is later technology out there, but this is going to have to work for now.
Any helpers out there? BTW....Engine is a 98 LT1 prepared by Woodro Josey.
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 06-24-2013, 07:31 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Help with Accel Calmap 6.0
Tom Goldman was familair with Gen 6 Accel units as I recall...
I had a Gen 7 Accel....and they are a lot different....
Woodro used Holley's as many did I think...
A data logger or an A/F data recorder is very helpfull
I had both but used an Innovate LM-1 mostly....and was way off in some areas...mostly low speed part throttle.....wide open down track was not too bad....but consistancy and predictability was not good...in some conditions....
You have a very steep learning curve and it is not fun...but once it is setup right...they work fine...
Rich Biebel
S/C 1479
Stock 147R
Old 06-25-2013, 09:04 AM   #3
Signman
Liked 269 Times in 99 Posts
Used this system when first coming out with my stocker.
It's pretty straight forward. Just use common sense.
Newer systems offer more control but the real benefit is faster processor.
You need a data logger in some form. Old Innovate LM-1 will work and are cheap. I have 2 and will sell them.
Data log your run: RPM and O2 at least
Use the log to identify RPM areas which match cells in the fuel map. Average the O2 in that area. Calculate a percentage of change from logged O2 to target O2. Change the value up or down in the corresponding cell in the fuel map.
The best thing to do is find a good tuner with chassis dyno in in your area. Only better if the tuner races the same series you do. Run the car on the dyno, ask questions and run the car. have fun!
Old 06-25-2013, 10:15 AM   #4
John Nechiporchik
Frank, Thanks for the input . Your process seems simple and logical. I have a data logger and O2 sensors so I can use your approach.
Thanks again.
John
Old 06-25-2013, 06:44 PM   #5
SuperStock 1890
SuperStock 1890's Avatar
John,
Send me an e-mail. I think I can dig up some of my old maps and print them out for you.
Richscaz@hotmail.com
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
Old 06-25-2013, 07:12 PM   #6
Rich Biebel
"The best thing to do is find a good tuner with chassis dyno in in your area"
I agree with Frank 100%
Or get the fuel maps offered from the gent that offered to send them to you.....He knows those cars....
Trust me it is not worth wrestling with this.......
You will waste a lot of time and runs....or worse....hurt something in the engine from being too rich or lean....
I thought it can't be that hard......and no it isn't but you will waste a pile of time/runs and money getting there....and with the cost of racing today.... it is well worth paying for someones time to get a good baseline tuneup...
Rich Biebel
S/C 1479
Stock 147R
Old 06-26-2013, 10:27 AM   #7
John Nechiporchik
Originally Posted by SuperStock 1890 View Post
John,
Sent you an e-mail this morning.
Thanks!
Old 06-26-2013, 11:02 AM   #8
Signman
Rich will get you in the ballpark.
A chassis dyno session will make sure the tune is safe for your combination.
