Old 06-25-2013, 09:59 PM   #1
S/G 316H
Default lean out valve info for running alchol
Does anyone use a legris slide valve for a lean out valve and if so which one do you use part # ?
S/G 316H is offline   Reply With Quote
Old 06-26-2013, 04:50 PM   #2
SG192L
Default Re: lean out valve info for running alchol
Yes I use one you can get them from McMaster-Carr it is called a slide-sleeve brass valve part#4622k33 and the price is $23.61 I hope this helps you out.
SG192L is offline   Reply With Quote
Old 06-26-2013, 11:41 PM   #3
S/G 316H
Yes it does.
Does the 1/4 npt lean it out enough?
Old 06-27-2013, 05:58 AM   #4
SG192L
Yes I have no problem getting enough heat in the motor. I use barbs for 1/2" fuel hose. When the valve is open the motor pickup 500 RPM.
Old 06-27-2013, 05:42 PM   #5
S/G 316H
Thanks, SG192L
