Old 08-27-2007, 10:15 AM   #1
Joe Helms
Talking nitrogen
I used nitrogen in the slicks this past weekend for the first time, and noticed took more effort to bring smoke off the tires in the box, is this characteristic of N in the tires? Anyone have similar experience? Otherwise worked really well, much more manageble in the heat! Joe Helms
Joe Helms is offline   Reply With Quote
Old 08-27-2007, 12:42 PM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Re: nitrogen
Joe I spoke to the Hoosier rep earlier this year and he advised againt using nitrogen in the slicks and the reason being is that it will keep the temperature of the tires at a lower point and not allow them to hook as well. I am currently using nitrogen in my front tires and find that my front tire pressure is very stable.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-27-2007, 03:23 PM   #3
Joe Helms
Mark, I had heard similar comments, thought I would try anyway. On bias10.5/30s, track temp 130f and tires 180f had no problem with traction or consistency, in bracket setup. Main advantage was much easier heat management! Sidewalls show a little discoloration, though.. Joe.
Old 04-12-2010, 01:27 PM   #4
mopar jeff
mopar jeff's Avatar
Bringing this post to life again. Anybody have any thoughts on using nitrogen in a stocker. Is it worth the investment, since you check them everytime before you run anyway? Does it give any ET advantage?
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 04-12-2010, 01:57 PM   #5
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i want to know if there's that much difference between 80% N and 95% N....and if there's that much difference, can you PROVE it?
helium makes better sense to me cuz 80% nitrogen is whats already in the air....
Old 04-12-2010, 02:20 PM   #6
63corvette
Liked 359 Times in 103 Posts
First, I am not for it or against it but it is the make up of the air we breathe is the big difference.
Its the moisture in the air that makes the pressure go up and down radically with heat or cooling in the tires.
With nitrogen there is almost no moisture as to bottle the Nitrogen it has been cooled to liquid which requires cooling it to if I remember correctly about -190 degrees C therefore there is basically no moisture in it.
Bottled nitrogen is made from air because there is so much in the air we breathe.
Helium is much more expensive and much lighter which would make it less stable with temp changes. It also leaks out much easier.
Just My 2 Cents
63corvette is offline   Reply With Quote
Old 04-12-2010, 04:06 PM   #7
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Helium wouldnt work in a tire well for a couple reasons. but it on top of that is a HUGE thermal dispersant.
If youve ever breathed helium ox mix in mixed gas diving....well itll litteraly suck the heat out of you from your lungs......unless its warmed, and youre in a hot water suit great way to go hypothermic in about 20 minutes flat.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 04-12-2010, 06:02 PM   #8
Tom keedle
Tom keedle's Avatar
oops, i forgot the "".......it was a joke (about the helium,EVERYBODY knows hydrogen is the hot ticket)
Old 04-12-2010, 06:11 PM   #9
mopar jeff
mopar jeff's Avatar
I have never seen that much variance in my tires, even on back to back runs, with just regular air . That is why I am asking the question. I can't see the logic in it, or the expense, but I am open to opinions.
Jeff Interlicchia
Old 04-12-2010, 06:54 PM   #10
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Simple, nitrogen makes your tires run cooler. You will have too heat them longer to hold the heat this will = faster tire ware costing you more than the worth of buying nitrogen.
Bob Pagano A/SA
