Well, after waiting for nearly 2 months, cant get SMith Machine(Schubeck style) lifters for my Pontiac... I guess they are having problems getting them done, by whoever is doing them. So , i guess im gonna go with a regular steel lifter...ANy suggestions? For E or F/SA 400/330HP Pontiac....
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 1,874 Times in 422 Posts
Trend Tool Steel. They do have a limited travel model that passes NHRA tech for a hydraulic lifter in Stock.
I suggest at least a P55 lobe lock cast iron core, and nitriding.
Alan Roehrich 212A G/S |
Will check into them... Probably cant put them on a used cam?
Liked 11 Times in 1 Post
Cliff Sherman tool steel limited travel as well
Liked 10 Times in 6 Posts
Brent, I was told with a new cam, You break in cam with smith or schubeck lifter, then change to tool steel lifter, I think you would be ok on used cam, but i don't build my motors. Tom
Tom Moock 5704 STK |
To my knowledge Trend does not make a Pontiac lifter. Pontiac lifters are the same diameter as a Chevy but Pontiac ones are taller. Putting a Chevy lifter in a Pontiac can cause the oil gallery to become exposed at the top of the lifter when the lifter is on the base circle and or the lifter oil groove to become exposed on the bottom side. I can’t remember which it is, it’s been a few years since I decided to see if Chevy ones would fit. I would just use the Sherman lifters. If you really want to use ceramics I have a used set. I quit using ceramics years ago.
Bill Edgeworth 6471 STK |
Hey Bill, in your opinion, is there much ET between the 2? Im planning on being in the 6500 rpm range...What about spring pressures? I might be interested in the used Ceramics...let me know what you need for them, and if they need resurfaced.... Thanks, BRent
Guys, if something is not in a catalog, pick up the phone and ask. It's not that difficult! PPP just made me a set of AMC TS lifters and there were none in the catalog. I just sent them a lifter I wanted copied and in less than 4 weeks had a set. Didn't cost extra either. Now it's available for everybody.
If I sat around looking at catalogs for availability while building an AMC, I'd never get it done.
Jeff Lee 7494 D/S '70 AMX |
Liked 83 Times in 20 Posts
Brent, you are so lucky you did not get those sm lifters. Jeff is right about PPP listers. Sm lifters destroy engines! Sad but true. Until they improve quality control, tool steel is the way to go.
John Duzac D/S 4448 STK |
#10 | |
Liked 7 Times in 4 Posts
Bob Aceves, 746 E/SA A&M motorsports |
