Old 07-12-2013, 07:04 PM   #1
L79racer
L79racer's Avatar
Default Jerico 4 spd ratio?
Whats a good ratio for a 550 hp motor with 4.56 rear gears at 3000lbs? I know its a little vague.
L79racer is offline   Reply With Quote
Old 07-13-2013, 12:10 AM   #2
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: Jerico 4 spd ratio?
You need to call Jerico and be a little (actually a lot) less vague. Any other advice at this point is pure speculation and pretty much useless.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 07-13-2013, 08:46 AM   #3
tj310
30 x 9 tires ? smallblock ? we switched from a 3.25 first with a 5.57 rear to 2.75 x 6.0 ,similar results . If I were buying new 3.08 ---Trevor
Old 07-13-2013, 09:56 AM   #4
james schaechter
The standard Jerico ratio that you see is typically a 3.19 low. If you don't have adequate hook, maybe 3.08 or even less, but only if you are working around less then ideal set up like a street strip car or small tire combo that does not work well. Clutch plays a big role. 4.56? Low rpm engine or street strip? If you can't hook the low gear and adapt the ratios to compensate, get a gear set that is easier to upgrade. Make sure the forst gear set is 33/15 and work with Scott at Jerico to pick the rest. If you plan on ramping up the car to handle the more traditional race ratios, it makes a difference. If you do it right, you can then change only main drive gears to go to a 3.19. If you pick some weird ones, it gets expensive because you have to choose a whole set.
James Schaechter 3163 STK
Old 07-13-2013, 10:44 AM   #5
Run to Rund
Liked 55 Times in 28 Posts
After a discussion with Scott on my fairly similar combination, I got 3.08, 1.93, 1.34 iirc.
Old 07-14-2013, 11:41 AM   #6
L79racer
L79racer's Avatar
Thanks for the replies, Its a 383 small block chevy. I will be shifting at 7200 and should be going through the traps about the same. Probably a 29x9 tire. Once its done If needed might go to 4.88. It will be a 4 link so hooking should not be a problem. Clutch will be a ram adjustable. I see a lot have the 3.08 1.93 1.34. If you go to a 3.19 what do you bring second and third to?
Old 07-14-2013, 09:10 PM   #7
james schaechter
http://www.jericoperformance.com/charts.htm
This lists the chart on gears. How much power and how much weight. What RPM do you plan on finishing at?
The reason I ask is that your shift rpm doesn't seem to match your gear selection. Not saying you are wrong. Just need more info. If youhave the power and torque to run a lot of mph, then maybe you need a 2.90 something first gear. If not and you can't handle the rpm on the other end, maybe reconsider the shift rpm also?
Old 07-14-2013, 09:48 PM   #8
L79racer
L79racer's Avatar
Why doesnt my shift point match gear selection? I used to run a Nash 5 speed then switch to a glide. Its been 9.92 at over 134 mph at 2900lbs.. With that Mph and a 29" tire it was going through the traps around 7000 plus or minus a few rpms. I dont want to be going through the traps over 7200.
Old 07-23-2013, 09:35 AM   #9
james schaechter
The short tire at 134 answers the question. The detail in the last post is helpful. Definately not set up for best e t so that makes it pretty easy to choose. It depends on if you have any future plans to change the car. Sounds like the car has more than enough power to run 3.08 or even like a 2.93 or so. Only you have enough info to decide, but it would be good to discuss the ratios with Scott at Jerico so you don't pick something odd that is hard to change later. Good Luck!
Old 07-24-2013, 07:01 PM   #10
jscamaro1
Liked 3 Times in 1 Post
Seems to me you would be going the wrong way with the first gear. With that rear gear and small tire I would want a 3.19 way before a 2.93 or 3.08. Clutch setup might be tricky with not much ratio in the trans or rear end.
Ever call G-force?
jscamaro1 is offline   Reply With Quote
