Old 08-28-2007, 05:16 PM   #11
bill dedman
Liked 6 Times in 4 Posts
Default Re: Did I really see this?
I don't know if this is significant in any way RE Stock Eliminator, but I have been amazed at how quick some of the Oriental cars (many, built in the US) are.
I was 26 years old and a local strip (Des Moines, IA) Stocker tech man when th '64 GTO's hit the strips. I vividly remember that most of the Tri-Power 4-speed versions that were running on (skinny) OEM tires, and with buttoned up exhaust, and were showroom stock, struggled to run much quicker than 15-flat. Add slicks, headers, and a 4.56 gear along with a limited slip, and yes, you had a 13-second car, but most of the ones I saw running, ran 14.80's... through the mufflers, on street tires.
Car and Driver has recently road tested two cars that beat that number by half a second in showroom trim, and they're both FWD cars and both automatics.
The 2007 Toyota Avalon ran 14.40 at 99 mph, while the marginally-lighter '07 Toyota Camry with the same engine, ran 14.30 at the same 99 mph.
These are soccer-mom, grocery getters with NO "performance" pretentions. They share a normally-aspirated 3.5-liter (213.5 cid) 60-degree V6. At 268 HP, they make a little over 1.25 hp per cubic inch in showroom condition. If a Viper made that much power per cube, it would have 626 horsepower...
They're both about a half-second quicker than a showroom '64, 4-speed, Tri-Power GTO, if my so-called "memory" serves me correctly.
Dunno if either or both will ever make it into the classification guide (They're both assembled in the USA), but it seemed to me to be food for thought... Pretty quick for soccer-mom transportation, methinks....
Bill
bill dedman is offline   Reply With Quote
Old 08-28-2007, 10:03 PM   #12
Chris Hill
Liked 244 Times in 26 Posts
A 122 in3 engine factored at 197 hp. That's 5hp more than our little v-6. At that rating, it will be a challenge to run under the index. It's a 14 lb/hp class.
Old 08-29-2007, 12:34 AM   #13
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: Did I really see this?
In AF/S it would have to weigh 2731. In BF/S it would have to weigh 3420. Civics shipping weight is 2804. .472 lift cam, 11.0 comp ratio, 60MM TB. I'm not worried!
Old 08-29-2007, 06:57 PM   #14
Mike Meier
Liked 41 Times in 9 Posts
I'm suprised that they haven't been allowing foreign pick-up trucks in Stock all along. I know there is that one year of Mitsubishi in there but I have never seen anyone run one. Also, I see that Nissan is in the engine specs for 1993. What car/truck eligible for Stock used that?
Mike Meier
"World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough
Mike Meier is offline   Reply With Quote
Old 08-29-2007, 07:01 PM   #15
Earle Holt
Liked 4 Times in 1 Post
Default One other question about classifications
68 3835 O/SA Rob Goins, Plymouth MI, '98 Mustang 12.497 13.45 -0.953
(from the Indy qualifying sheet)
Why wouldn't this car be in one of the FI classes? I'm sure it's fuel injected.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 08-29-2007, 11:38 PM   #16
JRyan
Liked 112 Times in 31 Posts
Even more amazing is the fact that THE CAR OF NHRA for years, the Pontiac Grand Prix & Grand Prix GTP are not even classified in the tech manuals. We had two we were going to run, and neither Len I., or any of the honchos of the Grand Prix Specialty firms were able to break down the GM barrier. Len even mentioned those cars when they added the FWD classes. NO LUCK. So we sold the cars.
Well, I guess that's not so bad. Look at all the $$$$ we saved.
Jerry
Old 08-30-2007, 11:06 AM   #17
G Schenck
Liked 81 Times in 35 Posts
Default Re: One other question about classifications
Earle, the computer system is not always up to date. He might have registered a car in carb class and received another ride. Case in point. Lee Zane driving a 98 camaro running H/SA and J. Allen Sherman racing his Grand Am in SS/AH , which he registered his Grand Am but I believe he is driving Steve Kent's 68 Barracuda.
Greg
G Schenck is offline   Reply With Quote
Old 08-30-2007, 08:46 PM   #18
Earle Holt
Thanks, you were right Greg. He actually ran H/FIA according to the class runoffs.
