Old 07-24-2013, 10:52 AM   #21
west coast
Liked 227 Times in 74 Posts
Default Re: Anybody Have Video of the Epic Burndown in Stock at Sono
Hey Toby
This question has nothing to do with these guys but how the start system works. I have meet both. Anybody correct me if i do not have this right, this is how I thought it worked. Once a car pre stages the other car has 45 seconds to pre stage. Once a car stages the other car has 7 seconds to stage. Or does the starter have total control over the pre stage time? Want to know how it works for future incidents if this happens to me.
west coast is offline   Reply With Quote
Old 07-24-2013, 10:56 AM   #22
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Originally Posted by west coast View Post
Hey Toby
I think it's 15 to pre stage (starter can over ride this)and 7 to stage
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 07-24-2013, 12:00 PM   #23
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
As far as open loop VS closed loop, one relies on a base fuel map vs the engine rpm or throttle position. The other ties into the on board Global Positioning System and wheel speed counters and makes it extremely consistent.
"Go With Confidence"
Tommy Gaynor is offline   Reply With Quote
Old 07-24-2013, 12:32 PM   #24
Liked 10,820 Times in 2,249 Posts
Its that old west coast rule book thing again! And the good part was no water was lost.
Old 07-24-2013, 12:59 PM   #25
Jim Kaekel
Liked 535 Times in 110 Posts
Originally Posted by Kevin Zaskowski View Post
Brad is correct, we didn't race anyone named twoputt9....but, since twoputt9 is actually Michael Wesokowski from division 7, you would be referring to my Uncle Bill that put you on the trailer round 2. My uncle must have had his closed loop system off, and didn't have his 327 warmed up from the 1 mile trip to the lanes from our pit spot.
Can't all you darn Polocks just get along?
Jim Kaekel 3836 STK
Old 07-24-2013, 03:14 PM   #26
Toby Lang
Liked 2 Times in 1 Post
Originally Posted by Tommy Gaynor View Post
When we pulled out of the lanes to the ready line my car was about 85 degrees. The way I run my car it has to be 115 degrees for the fuel injection system to go into closed loop. If it runs in open loop below 115 degrees it shoots numbers all over the place. I did my burn out with the water pump off, didn't move much so I started stalling it up against the convertor with the fan and water pump off. It slowly started warming, as per the rules I kept making forward motion as it warmed up. The starter waived me in one time and I kept bumping forward.
I just assumed you noticed that your temp was low after the burnout and that's why you took so long. If you noticed the temp was low when they pulled you to the ready line, why didn't you start getting on the convertor then instead of waiting until after the burnout? I wouldn't think it would take that long to get it from 85 to 115 degrees. Also, you could have stopped behind the burnout box and got on the convertor like some people do to test their transbrake. I would have been stalling it from the second I saw the temp was low. I don't know about your car, but on mine the temp gauge doesn't really move unless you toggle the water pump.
According to your interpretation of the rules, when the starter waves you in all you need to do is make forward motion? If that's the case, I should be able to take 15 minutes to stage as long as I make forward motion, right? I've always heard when the starter waves you to stage you are supposed to stage like ... NOW! Not just make inch bumps towards the line or stage whenever you feel like it.
You say you felt awful about it after the race, but when you were doing it you had to know that you were hanging Jim out to dry and his car was heating up. But, you got your car up to the proper temp and that's all that matters.
Old 07-24-2013, 03:16 PM   #27
Toby Lang
Hey Toby
Never heard of a pre-stage timer, but I believe you get 10 seconds to stage in most of the sportsman classes and 7 seconds for the pros.
Old 07-24-2013, 03:17 PM   #28
Christopher Stilwell
Hey Toby
The Compulink timing system does not have any set time for Pre-Stage set in it. The starter would have the control of making someone pre-stage if they feel they are taking too long to do so. The stage timeout limit is set at 7 for the Pro/Alcohol classes and 10 for the Lucas Oil Sportsman classes.
Christopher Stilwell is offline   Reply With Quote
Old 07-24-2013, 03:39 PM   #29
west coast
This is what is in the rule book nothing about a set time to prestage or stage. Tommy you crack me up.
A reasonable amount of time will be permitted for drivers to stage.
The time limit will be determined at the sole and absolute discretion
of the official starter. Failure to stage upon the starter’s instructions
is possible grounds for disqualification. After proper staging and
receiving the starter’s signal to go, restaging for a second time is
prohibited. Any driver leaving the starting line before the start
system is activated, including a driver on a single run, will have his
or her time disqualified for the run.
Old 07-24-2013, 05:06 PM   #30
Tommy Gaynor
Toby what the *****! It's over! I can not take it back. I have made three attempts to apologize to Jim. I have explained myself and the situation in a public forum and people will all have their own opinions. I don't know what you want to do from here, we could do it old school and I could come see you at the Seattle National and we could fist fight? Or we could do it NASCAR style and Jim could wreck me next time we race, or even better NASCAR pit crew style and we could have a brawl with jack handles! Just let me know what you are thinking and I'll make sure my car is warmed up! Seriously aren't you both over 50? I thought maturity came with age, maybe I'm wrong again.
