Old 07-24-2013, 10:40 AM   #11
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Which is faster carb or Fuel injection?
With or without the AHFS?
Bill Grubbs is offline   Reply With Quote
Old 07-24-2013, 02:30 PM   #12
Joe DeMarzo
Liked 121 Times in 11 Posts
Bill: I was comparing two motors, two different cars same HP and basically same specs with the only difference being carb vs EFI.
The FI cars leave harder in lower HP cars then the carb cars, I am not sure in higher HP cars because they all leave hard.
Looking at slower cars in my older age...
Joe DeMarzo 1317 STK
Old 07-24-2013, 02:42 PM   #13
B Parker
Liked 2,343 Times in 465 Posts
Joe Didn't you go a 10:92 in H/SA at Atco this year? How fast do you want to go? I don't see many older Fi cars going 1:23 under. You just have to much time on your hands. Barry
Old 07-24-2013, 03:27 PM   #14
Pistol Pete
Pistol Pete's Avatar
Liked 797 Times in 211 Posts
That's tellin 'em Spanky.
"Pistol" Pete Dutko
Pistol Pete is online now   Reply With Quote
Old 07-24-2013, 03:40 PM   #15
Joe DeMarzo
Talking Re: Which is faster carb or Fuel injection?
Brother Parker, you taught me everything I know.... but not everything you know about going fast. Your vette is still sleeping, when are you going to wake that thing up????
I lost something at Lebanon Valley and can't find it, thinking keeps me young.
Old 07-24-2013, 03:55 PM   #16
B Parker
Joe where have you been hiding. You going to Indy. We are thinking about it. If your not going I may run H. Barry
Old 07-24-2013, 05:00 PM   #17
Bill Grubbs
Joe, I know what you meant...
Old 07-24-2013, 05:27 PM   #18
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
This is just our experience, but like has been said in previous post, if everything is apples to apples, their is no noticeable difference. Tuneability and the ability to squeeze out every little hundredth is a big plus for the F.I. The comparison on fuel readings off the Egts are not even close, and we have a pretty well tuned carb. You can get the F.I to somewhat flat line the target fuel curve, and you just are not going to do that with a carb.
We broke in, then dynoed our engine with a carb, and then a box manifold/F.I set-up, and lost 13 horsepower with the F.I. .. The carb was a 750 Q-Jet, but our combo uses the stock 48 mm tuned port (L-98) F.I throttle body, and those little bores suffocate a 350. I am guessing on a 305, the numbers would be closer as not as much air would be needed for good power.
Jeff Niceswanger 3740 SS
Old 07-24-2013, 05:35 PM   #19
Signman
Liked 269 Times in 99 Posts
With my last engine we did a test to see if there was a big problem with my EFI setup and took off the tune port and put on a 350 manifold, not the best but good and a dyno Q-Jet and picked up 20 HP. Nothing else changed.
Old 07-24-2013, 06:47 PM   #20
Lee Valentine
Liked 319 Times in 68 Posts
Joe, on Bryan's 305 the carbureted combo made 20 more horsepower than the F.I. and made power at a higher rpm. The F.I. combo makes more torque and has a flatter torque curve. run at the same weight the carb is faster.
Lee Valentine 1661 STK
