Old 07-30-2013, 08:56 AM   #1
Ben Kallies
Default Aluminum BBC - Spark Plugs
I'm looking for spark plug recommendations on a 427 BBC street/strip motor with GMPP aluminum heads, 10:1 compression, .570 lift flat tappet cam. Using a mixture of premium and race gas. I'm hoping for actual part numbers, not just a brand preference. Of particular interest is the heat range suggested, as well as whether I need a .460 or .750" reach. Thank you in advance.
Ben Kallies
B/S 3069
Ben Kallies is offline   Reply With Quote
Old 07-30-2013, 12:50 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: Aluminum BBC - Spark Plugs
Ben,
Edelbrock calls for a Champion RV12YC They make the heads as far as I know so that should be a good starting point.
Bill Koustenis
BillK is offline   Reply With Quote
Old 07-30-2013, 02:04 PM   #3
Liked 1,919 Times in 432 Posts
RC12YC Champion. It's 0.750" reach, projected tip, and 5/8" hex. Easy to find, affordable, reliable, and consistent.
Old 07-30-2013, 07:18 PM   #4
BillK
My bad, I could have sworn the catalog at the shop said RV12 ??? Just looked at the web site and sure enough RC12
Bill Koustenis
Old 07-31-2013, 12:23 PM   #5
Ben Kallies
Alan; Bill,
Thank you for your replies. I have one follow-up question: I notice that both of these are "resistor" plugs. Are resistor plugs better than non-resistor plugs in a hi performance application, or doesn't it matter? Thanks
-Ben
