Old 08-07-2013, 04:48 PM   #11
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Default Re: Ok?
I don't want to step on Chuck Blossom's toes, lol. I can't imagine that 302 2 bbl going 13.85 let alone 12.85!
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 08-07-2013, 05:06 PM   #12
rawhide
Liked 7 Times in 5 Posts
Default Re: Ok?
What I find confusing is that every year from 1972 through 1979 has a different hp rating. 1980 and 1981 have two different ratings of 130 and 132 each year. 1982 has two of 132 and 157 for the GT engine. 1975 has the lowest which is 129. Hope I have not confused any of this.
regards, Roland
rawhide is offline   Reply With Quote
Old 08-07-2013, 05:08 PM   #13
Paul Wong
Liked 419 Times in 85 Posts
Default Re: Ok?
Dennis Breeden
If a 273 2 barrel mopar can run in the 12's. I am sure it will be no problem with 30 extra cubic inches. Your just used to thinking with a 1000 cfm throttle body. These are not cookie cutter cars. You have to think a bit outside the box. Thats where the fun is.
Paul Wong is offline   Reply With Quote
Old 08-07-2013, 06:21 PM   #14
Ed Wright
Ed Wright's Avatar
Default Re: Ok?
How do you read those? Mostly reductions? I don't see seperate columns for OEM and new.
Ed Wright 4156 SS/JA
Old 08-07-2013, 06:38 PM   #15
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: Ok?
just *****ng great....
every year just before indy a new -2 second p.o.s. shows up in U/SA... cmon nhra don't you guys really have a clue here... use the calculator on your phone....
captain jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 08-07-2013, 07:13 PM   #16
Nick Heath
Liked 566 Times in 135 Posts
Default Re: Ok?
Ed, you have to check each individual year (e.g. 1978 Ford) to see what they were reduced to.
I can't figure out what the reduction is on the 2000 LS1 though??
I wonder if NHRA realized that it did not make sense to rate a '72 Maverick, a '78 Mustang, and an '82 Mustang all at the same HP. So they rolled the HP ratings back to what they were from the factory, without realizing that the factory ratings weren't worth anything to begin with!
Or is this some elaborate plan to win back Ford's support and $$$?
Old 08-07-2013, 08:54 PM   #17
Ed Wright
Ed Wright's Avatar
Default Re: Ok?
The 2000 LS1 reduction surprised me. I figured I was reading it wrong. The bone stock, untouched automatics made more than the factory rating, at the tires, on my chassis dyno, totally untouched. Stick cars made more, of course, than the automatics. Figure a 20% loss through the drive train. Best automatic cars make in the 330s at the tires.
Old 08-07-2013, 09:08 PM   #18
denbreeden
denbreeden's Avatar
Default Re: Ok?
So Ed, you're saying the LS1 is under factored like the new cars????
Sorry, I had to pull your chain.
Dennis
Old 08-07-2013, 10:09 PM   #19
Ed Wright
Ed Wright's Avatar
Default Re: Ok?
Dennis
It is under rated. Not nearly as much as the new cars. Mine isn't an LS1, it is an LT1. I have seen only a couple of freak automatic LT1s make more than the factory rating of 275 at the tires. They had headers and tuning. Normally they make 235 to 250. Maybe I need to put a 2000 model front clip on mine, and an LS1 in it. The aluminum head LT1 Stockers have a lot of work the tech guys can't seem to see. The set I flowed weren't all THAT much behind my SS ported heads. Nothing like factory castings I have tested. That, of course, is reflected in the hp they have earned in Stock. :-)
Old 08-07-2013, 10:20 PM   #20
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Default Re: Ok?
Does anybody see what hp changed for the LS1 in Stock?
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
