Old 08-13-2013, 07:30 PM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default 4130 chrome moly tubing
What is the correct TIG wire for welding 4130 tubing ?
Thank You Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 08-13-2013, 07:50 PM   #2
NHRA 303
NHRA 303's Avatar
Default Re: 4130 chrome moly tubing
HI Kenny. The wire that any welding supply store would recommend is 70s-2. If your tiging .065 wall tubing. I would use 1/16 thick. At about 70 amp's setting.
steve
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
Old 08-13-2013, 07:51 PM   #3
LB Racing 3179
I use ER 80S-D2 and ER70S-D2. Some guys I know even use 308 Stainless filler.
LB Racing 3179 is offline   Reply With Quote
Old 08-13-2013, 08:53 PM   #4
Kenney Kelley
Thank You for taking time to answer my Question.
Kenney Kelley
Old 08-13-2013, 09:44 PM   #5
Darcy Clarke
Liked 594 Times in 38 Posts
The correct wire is actually ER80S-B2 which is 11/4 CR 1/2 moly same as 4130 tubing the D2 is 1/2 moly and S2 is for Mild Steel only.
Darcy Clarke
6254
A/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 08-13-2013, 09:53 PM   #6
Todd Geisler
Liked 345 Times in 149 Posts
ER80S-D2 or ER70S-6, 1/16" for most work.
.045 wire for thinner metal and 3/32" for heavier stuff like rear ends & 4 link brackets.
Todd Geisler is offline   Reply With Quote
Old 08-14-2013, 10:38 AM   #7
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
http://www.lincolnelectric.com/en-us...ly-detail.aspx
Good info
XSTOCKER is offline   Reply With Quote
