Old 08-22-2013, 09:52 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Full cage in a stocker.......subframe connectors ???
Does a full roll cage installation----not roll bar----delete the necessity of subframe connectors or do they serve different functions ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 08-22-2013, 11:46 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Full cage in a stocker.......subframe connectors ???
Putting a rollcage in without frame connectors is like leaving out some of the bars! It all works together, but the frame connectors are like the foundation in what's added to keep the chassis from flexing.
Old 08-22-2013, 12:02 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Full cage in a stocker.......subframe connectors ???
X2! Jim
Old 08-22-2013, 12:38 PM   #4
tj310
Default Re: Full cage in a stocker.......subframe connectors ???
First time I saw subframe connectors it was because the seatmounts had rotted through the floor ! If your starting with a rustfree unibody you may get by with the stock floor and rockers. ---Trevor
Old 08-22-2013, 12:44 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Aren't subframe connectors required with a cage?
Old 08-22-2013, 02:48 PM   #6
glen myers
glen myers's Avatar
Liked 2 Times in 2 Posts
Rusty....there ya go over-thinking it again....
glen myers is offline   Reply With Quote
Old 08-22-2013, 03:11 PM   #7
Rusty Davenport
thanks Glen, that was really helpful hahahahaha get the spray can out.
Old 08-22-2013, 04:11 PM   #8
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I believe if you order a 8- or 10-point rollcage for a uni-body vehicle, it is supplied with 6X6 steel plates to facilitate it's installation. Most of the "popular" vehicles have sub-frame connectors available, but I personally don't believe that the connectors are an adequate substitute/replacement for a full frame when installing a roll cage. Just one person's opinion!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 08-23-2013, 11:24 AM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Frame connectors are a necessity to keep the front spring boxes from pushing out .
With modern torque converters , tons of gear ,radials and Caltracks, ect. , There is way too much force concentrated in that area to forgo the connectors.
Also be sure to tie the main hoop braces into the connectors.
If it's a Mopar or Ford, I also run braces from the front bars to the firewall area at the top of the fender trough,
You cant go thru the firewall in Stock , but you can brace it inside.
Old 08-23-2013, 06:43 PM   #10
Jeff Lee
Jeff Lee's Avatar
John Calvert ran his original 68 1/2 CJ Mustang (4-speed) for years with a bolt-in roll cage and no subframe connectors. I believe tech finally said no and he took care of it with a welded cage. Not sure if he has sub-frame connectors now. So can it be done? Yes. But is it wise? Not really.
One costly mistake I made was not placing rocker bars (at least on the drivers side) when I went from a roll bar to roll cage and switched to SS/H at the same time. Although I had sub-frame connectors from day one, even with a CM roll bar, the extra 100 HP, 6800-7200 RPM stick launches and Cal-Track system reeked havoc on the drivers side torque box causing an eventually dangerous ride. And it's been parked since. I believe rocker bars would have eliminated the problem. And it wasn't for lack of funds, that extra part may have been $20-$50. I just didn't think it through.
Jeff Lee 7494 D/S '70 AMX
