Old 08-21-2013, 09:15 AM   #21
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: GM A Body Drive Line Angles
James, not something to joke about and that's my only comment. This is a matter between Numidia Dragway and Mike.
Old 08-25-2013, 06:18 PM   #22
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by 1320racer View Post
it ain't about "go fast", it's about getting these cars to work and neither would you know anything about!
Meanwhile, show us your car no mind another GM A body that has gone 1.28 60 foot with a bolt on suspenion, using all and nothing but the factory mounting points, nothing welded and no anti roll bar, launching off the footbrake and weighing 3900 lbs.
The Proof is in the Performance!
The only 3900 pound Chevelle that I know of that runs 1.28 60s is Joey's B/SA LS6 Chevelle. Again I will say how is it possible for this car to weigh 3900 pounds when I have the same all steel 68 that weighs 3720 with bolted in weight? This is the only full weight stock suspension Chevelle 1.2 60 your ever gonna see Ed, Ive been asking for years now to see your 1.2 60 foot from your 10 sec production block chevelle. The proofs in the time slip.
Name:	Chevelle testing.jpg
Old 08-25-2013, 06:24 PM   #23
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
I was wondering the same thing.Unless you HAVE to weigh 3900 pounds in a Chevelle to make your legal Stock or Super Stock class weight,why would the car be that heavy and why would you run it that heavy all of the time?
Old 08-25-2013, 06:40 PM   #24
HP HUNTER
Hell, I had to put weight into my 68 so I could run at the weight everybody else claimed. This Eds car gets heavier every time he brings it up, don't forget the negative 1500 feet air the car was regularly raced in.
Old 08-25-2013, 06:56 PM   #25
1320racer
1320racer's Avatar
same old bullsh_t from you, you can't do it so no one can and that time slip means nothing as it relates to this thread or your latest failed attempt to debunk my former Chevelle's performance.
Post the full time slip with track info and date along with a photo of the car with the competition number on the time slip, on the car!!
AGAIN, when I sold my Chevelle that weighed 3880 lbs. going down the track with my cast iron headed 468 under the hood along with power steering and power brakes at the conclusion of the 2008 season, NO ONE that Alf was aware of running his suspension had 60 footed as quick as my car including Joe's former ride that weighed less and was sold to Adam Landolfi in 2007, maybe 2006.
Believe what you want, I've got the time slip, Alf has seen it, Herb Mccandless jr. witnessed the run at Piedmont Dragway on 11/24/07 and saw the incrementals.
Old 08-25-2013, 06:58 PM   #26
HP HUNTER
ok, just make sure that these others offering opinion have GM A body cars that leave on par with this one, launching off the footbrake and nearly 3900 lbs.
Ed, I think you know theres a list of full weight production oval port big blocks out of my shop that rape this red car of yours, just saying...
Old 08-25-2013, 07:03 PM   #27
HP HUNTER
same old bullsh_t from you, you can't do it so no one can.
Numerous replies by you in numerous threads on this site and others in your failed attempts to debunk my former Chevelle's performance.
I just want to see the time slip, should be simple to post it on up. Yes your car went some low 1.3s, but that not a big deal, and it sure doesn't weigh 3900 pounds. Come on Ed your not even turning the fan....
Name:	Ed Bigley.jpg
Old 08-25-2013, 07:04 PM   #28
1320racer
1320racer's Avatar
3880 lbs. witnessed by many on the scales, get over it!
Meanwhile, 6 years after my Chevelle posted a 1.28 60 foot time and 5 years since I sold it, it's still the benchmark for you and many others!
Work harder and one day YOU might be able to duplicate it!
Old 08-25-2013, 07:11 PM   #29
HP HUNTER
I think you know who sets the bar.
Old 08-25-2013, 07:11 PM   #30
1320racer
1320racer's Avatar
I've got no time to debate the same old sh_t about a car that I sold 5 years ago but for those that want to know, there's several threads here including this one...
http://classracer.com/classforum/showthread.php?t=40441
with more lies and failed atttempts by this poster.
BTW, my current car, has 60 footed 1.17 weighing 3144 lbs., n/a and launched off the footbrake, want to debate that too?:
