Old 08-25-2013, 08:27 PM   #1
ant1277
Default Oil pan for Big Block Nova
I have a 72 nova looking for some oil pan choices.
Thanks
ant1277 is offline   Reply With Quote
Old 08-25-2013, 09:02 PM   #2
sg1586
Default Re: Oil pan for Big Block Nova
Just hack up the one you have till it fits!!!!!
Or call Lou and he can get you a custom aluminum one...
sg1586 is offline   Reply With Quote
Old 08-26-2013, 11:57 PM   #3
Grant Eldridge
Grant Eldridge's Avatar
If it is the same as a 1970 Nova, as I think it is, then the LS6 oil pan was the biggest factory pan we could find to clear the steering. Even then, you might need to do a little "clearance" work with a hammer at the front corners to ease the closest points on each front edge. Of course, there are many non OEM pans to choose from, I'm assuming you want a GM pan that will be as large as possible to fit your Nova. As I recall, mine was about $125. from Sallee Chevrolet in Oregon a few years back. We had factory manual steering, not sure if power steering linkage would alter the clearance...
Grant Eldridge
Grant Eldridge is offline   Reply With Quote
Old 09-01-2013, 11:18 PM   #4
Barry Polley
Guest
Posts: n/a
http://www.champpans.com/products/c/oil-pans/
I run their stocker pan and they have many aluminum and steel pans to choose from.
Speak with Jake.
