Old 09-04-2007, 10:17 AM   #1
Marty Buth
Liked 232 Times in 39 Posts
Default Valve Diameter Tolerance
What is the tolerance on valve diameter from the NHRA apecification?
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 09-04-2007, 10:56 AM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Valve Diameter Tolerance
2007 Rule Book Pg 55. "Valve diameter tolerance +0.005" or -0.015" from NHRA specs."
Bill Harris is offline   Reply With Quote
Old 09-04-2007, 10:58 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
From the rule book under section Engine:1, Cylinder Heads, "Valve-diameter tolerance: +.005" or -.015" from NHRA Specs." You do have a rule book, don't you?
Old 09-04-2007, 12:28 PM   #4
Marty Buth
Thanks for the response. That was my memory, but didn't have the rule book handy.
Marty Buth 3657 STK
Old 09-04-2007, 01:42 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,981 Times in 597 Posts
Marty,
Make sure that you check the NHRA specs. They dont always match the OEM valve size. I got tossed for an intake valve that was - 0.016. By Westley of course.
Mike
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 09-04-2007, 02:22 PM   #6
Marty Buth
Mike,
Thanks for the heads up. My brother and I both run 2300 ford motors and they are different, even though you can buy a lot of valves that are after market for both years of our cars.
Thanks,
Marty
Marty Buth 3657 STK
