Old 09-05-2007, 02:22 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face remote oil filter adapter?
dose anyone make one for a 307 olds? Perma cool has one that they say fits 95% of all engines...but goes on to say call tec to make sure it will work with your combo? if you've seen where the filter is on a 307 olds you would know why I want to move it.
Old 09-05-2007, 05:42 AM   #2
Default Re: remote oil filter adapter?
Greg, put a small diameter filter on it. Short or long ones are available. Same as 301 Pontiac. PF 47 ,I think
Old 09-05-2007, 08:01 AM   #3
Liked 1,892 Times in 423 Posts
Try Trans-Dapt. I know I just put one on a Pontiac 455 for the exact same reason, and it worked fine. I used to run an Olds all the time, I tapped the holes in the block on mine, and used AN fittings.
Old 09-05-2007, 08:59 AM   #4
FED 387
Liked 333 Times in 180 Posts
Yep ---Trans Dapt part # 1420 I believe--Comp 387
Old 09-05-2007, 01:36 PM   #5
greg fulk
greg fulk's Avatar
Smile Re: remote oil filter adapter?
Thanks guys! that thing sets so close to the header it has to be like having an oil heater!
Old 09-05-2007, 02:14 PM   #6
Rusty Davenport
Liked 101 Times in 27 Posts
Unhappy Re: remote oil filter adapter?
careful on the remote oil filter-----I spent a fortune on plumbing and the best pieces available----after a few runs the bearings were gone, crank and rods got so hot they turned black-----went to a short filter after a rebuild. Just my humble experience.
Rusty Davenport is offline   Reply With Quote
