Old 09-04-2013, 01:46 PM   #91
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: You got to be kidding?
Bravo! An informative post from a racer who is doing something other than complaining, speaking to the NHRA and trying to come up with a cost effective and approved solution.
Old 09-04-2013, 02:55 PM   #92
Shawn Blair
Shawn Blair's Avatar
Thumbs up Re: You got to be kidding?
Originally Posted by A56 View Post
I have had a meeting with Danny Gracia this past week at Indy. We have talked a few times previously, and NHRA tech along with other header fabricators input have come up with some ideas and I believe have come up with a final solution which should be in writing very very soon.
To begin this rule is absolutly nessesary, there have been lots of incidents and people have been seriously hurt. NHRA has to cover there butts from further incidents, and keep racers from getting hurt in the future. I believe this is a good rule, and now that simple collector retention devises have been thought of, it will be simple and inexpensive for each one of us to install.
The Lokar Collector Tether and the Tether previously mentioned are not going to be the final requirement, im sure you can use that type of system, it will be very effective, but the cost will be to high. Believe it or not, NHRA does not want each of us racers to have to buy a tether system that costs that much. They also dont want us running to Home Depot and fabricating something out of low grade materials. Again, this tether system will work great, and it will be approved for those that have already purchased it.
What has been proposed and is pretty much is a simple wing tab kit with a nut and bolt. Originally I had proposed this with a lock nut, but it was rejected due to the fact that the lock nut could fall off. What has been decided on is to use the wing tabs and a nice aircraft bolt with possibly a castle style nut and a cotter key. This system will be in addition to our already existing spring tabs or A/B collector tabs. The actual Bolt / Nut / Cotter Key has not been decided on. I dont know if it will be a 1/4", if it will be a castle style, and what the clip or cotter key will have to look like. But what I do know is that it will be simple and inexpensive.
NHRA was actaully great to work with on this situation. They just want something simple, safe, and inexpensive for us racers. So dont go jump the gun on buying parts just yet. Give this all a little while till we see it in writing. I will be stocking all the parts needed for the fix, but not until its in writing. I think once its all said and done well have a solution to our problem for 30 to 40 bucks using stainless tabs and aircraft hardware.
Mark Lelchook
D/ED F/SA
Mark,
This sounds way better! Thanks for the time and effort spent on this!
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 09-04-2013, 03:44 PM   #93
KThomas
Liked 6 Times in 4 Posts
Thanks Mark ................
KThomas is offline   Reply With Quote
Old 09-04-2013, 03:45 PM   #94
Randall Klein
Liked 316 Times in 67 Posts
Good old 1320racer now jumps in and applauds a reasonable solution, mainly brought about by the "whining" of class racers and someone who knows (A56) about the subject
Quite a change from post #72 wherein 1320 tells concerned racers to "give up" and spend the measly $200, as he was going to do.
Message boards and open communication (that some paint as "whining") can and do effect change.....there is power in numbers
Recently board whining seems to have had an impact on start line prep and a possible mea culpa from Tom Compton
Whine on fellow class racers....somebody is paying attention, regardless what naysayers like 1320racer say
Old 09-04-2013, 04:00 PM   #95
1320racer
1320racer's Avatar
you clearly failed to read good old 1320racer's post #52 wherein 1320 states...
Originally Posted by 1320racer View Post
Bottomline is collector tethers are required as of 2014 and until someone else comes up with an NHRA accepted solution as well cheaper solution, you will be buying these tethers or welding your collectors.
as well his post #62
I have yet to read one post where a racer has stated he is going to invest his time and money to produce another solution, get it approved by the NHRA and sell it cheaper than the current solution.
Old 09-04-2013, 04:14 PM   #96
buzzinhalfdozen
Liked 11 Times in 8 Posts
Hey dipstick..."complaining " probably persuaded some folks to "do something" ever give that a thought? Everyone simply doing as they say indicates everybodys OK with it. What did you do? I'm hoping you already ordered your mesely $200 kit..jacka$$!
Joe Buchanan SS/BX 3117
Old 09-04-2013, 04:21 PM   #97
1320racer
1320racer's Avatar
buzzinhalfdozen aka class racer's resident moron, I mean "master tech" continues to try and entertain us.
Old 09-04-2013, 04:50 PM   #98
Ed Wright
Ed Wright's Avatar
You buffoon, I wish you would put an LT1 in that car and run SS.
Ed Wright 4156 SS/JA
Old 09-04-2013, 04:56 PM   #99
1320racer
1320racer's Avatar
why would turn my rocket into a turd to race on a junk track for peanuts and be treated like sh_t by the sanctioning body?
Old 09-04-2013, 04:59 PM   #100
Ed Wright
Ed Wright's Avatar
I think we would all enjoy it. LOL
