Old 09-05-2013, 09:38 AM   #71
Signman
Liked 269 Times in 99 Posts
Default Re: Crank Trigger
Leave your distributor installed ready to go after setting up the crank trigger. It will serve as a backup.
Old 09-05-2013, 09:40 AM   #72
buzzinhalfdozen
Liked 11 Times in 8 Posts
Originally Posted by 1320racer View Post
Jamie, you made your decision about your car and your money, good for you. Me, I must be doing something wrong when a guy with a mid 11 second car is convinced based on the opinions he reads on an internet forum that the addition of a crank trigger will reward him with quicker and or faster MPH on the time slip due to "more stable, rocky steady" timing yet I've got about 4000 10 second time slips, 1000 9.0x time slips and numerous 8 second time slips from two BBC combos with billet distributors that every time I've set the timing it too is steady at RPM. Further, the clamp has never loosened, the timing has never changed due to oil viscosity and temp and never in over 2 decades have I had to constantly monitor a distributor for fear of component wear but wait, it gets more crazy...the MSD billet distributor in my 950HP BBC has ~ 18 degrees of mechanical advance in it. Yep, you read right, it is NOT locked out yet somehow, I'm able to make pass after pass after pass where my 60 foots and ETs typically vary thousanths(.00x) on any given day. Guess I'm just lucky or maybe all this talk about more stable timing means NOTHING on the time slip with engines like yours and mine.
Again, Jamie, your car, your money, your time, your decision.
Finally! you made some accurate statements, you are in fact "doing something wrong" when you flat out state that a dist. based trigger system is as good as a crank trigger. However I'm left to assume you're running a belt drive oil pump since you've stated you've never had a worn dist gear with "thousands" of runs....well you must have one of those unobtainium gears. The mere fact that you run advance in your dist. means nada, who cares but why unless you street drive it. I've not read one post where anyone stated they saw a gain in E.T. or MPH, so why do you insist on flapping your gums about that? Nearly everyone that replied (you being the one and only exception) simply stated they saw an increase in timing stability or stated their engine "seemed" to run better. Your statement that increased stability in the timing is the same as stating valve train stability is unimportant, which indicates a total lack of knowledge in the matter.Please refrain from further discussion on this matter unless of course you can supply a credible second source for your argument.
Joe Buchanan SS/BX 3117
Old 09-05-2013, 10:45 AM   #73
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
funny that the masterbater aka tech claims his skill set allows him to be able to "diagnose and repair modern vehicles" but is clueless, no surprise, as to why I run mechanical advance in my distributor. His guess is because he thinks I drive my MPR built Super Stock car on the street.
WRONG, care to try again?
Old 09-05-2013, 11:11 AM   #74
buzzinhalfdozen
Oh Ed, first and foremost you do not posses a "super stock" car you merely have a possibly legal car with a bracket motor.....so you have a BRACKET CAR period! BTW I drive an F1 car to work...minus of course a legal engine, chassis, ect...well it could be an F1 car right? Any "claims" I've made are easily backed up by the many certificates I've earned from the general motors technical college. Yes I'm a bit mystified by your desire to have advance in your timing though the reasoning behind it I don't care to know as it's of no benefit to me. Dump truck motors may indeed run exceptionally well with a bit of advance, not sure as I have an actual LEGAL super stock engine. So the next time your "modern vehicle" breaks down on ya, please inform me of how you got out with some tape and pliers and got er going again. Good luck. Oh and 1 more thing since you have all those "freinds" including what you say include stock and super stock racers why haven't any of them come to support you claims?
Old 09-05-2013, 11:39 AM   #75
1320racer
1320racer's Avatar
too funny and WRONG, guess again!
Old 09-05-2013, 11:46 AM   #76
Mike Casteel
The only logical reason would be for easier cranking, but they make start retards for that....
Mike Casteel is offline   Reply With Quote
Old 09-05-2013, 11:50 AM   #77
buzzinhalfdozen
Since you flat out refuse to answer any question posed to you I'll leave you with 2 final thoughts...first I find it ironic you use the word "clueless" adressing others as it's spot on describing yourself. Second I'll be watching to observe any and all second party input on the matter that support your statement with just 1 fact or example to back it up.Again....good luck.
Old 09-05-2013, 11:53 AM   #78
buzzinhalfdozen
Oh I think 1 retard in that car is enough.
Old 09-05-2013, 12:53 PM   #79
copperhead
Anyone in particular in mind?
copperhead is offline   Reply With Quote
Old 09-05-2013, 03:10 PM   #80
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Now thats funny for sure.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
