Old 09-10-2013, 03:40 PM   #1
JCChildress
JCChildress's Avatar
Liked 11 Times in 5 Posts
Default Sheet Metal Intake for 327
I'm just curious as to why no one runs a sheet metal intake on 327 or 350 Super Stockers. I know its hard to beat the cast ones on the single four barrel deals but surely somebody has the resources to make it work.
JCChildress is offline   Reply With Quote
Old 09-10-2013, 05:04 PM   #2
Tom Nolan
Liked 64 Times in 11 Posts
Cool Re: Sheet Metal Intake for 327
I had several sheet metal intakes made for my GT/TA 1970 350 LT1 powered S-10 truck....the thing was way fast in the end! The friend I sold the truck to still runs it! Hogan was the only intake that worked { I spent a lot for pretty looking door stops}. I had originally tried to make it run with a Q-Jet combo but it just hated it, and finally switched to the Holley combo. The smaller plenum was the ticket, most combo's don't have enough motor to hood clearance.....55-57 Chevy's and S-10's are the only combo's that I know of having the space!
Tom Nolan is offline   Reply With Quote
Old 09-10-2013, 08:19 PM   #3
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
Default Re: Sheet Metal Intake for 327
Wilson manifolds took one of our aluminum intakes and completely reworked the runners and raised the plenum slightly. I guess you could say they did some proprietary work, research, flowing, etc on the intake before we got it back. You could tell that there was some work and that it was not your run-of-the-mill Victor Junior. We were still able to fit the q jet under the hood without problems. I am not sure what the "model number" is to it after they redid it. We sold the motors several years ago and gave the intake to Dave Layer. Dan Jacobs now has it on his flying Chevy II.
It looked promising on the numbers and all. We didn't have the time to do A B A testing. This was on our SS/IA Camaro. This all occurred when professional and family obligations trumped racing.
FWIW
Ronnie Smith Jr is offline   Reply With Quote
Old 09-10-2013, 08:57 PM   #4
Jeff Lee
Jeff Lee's Avatar
Not having had a sheetmetal intake, I'll just say I believe the worst factor is harmonics and every effort should be made to control them.
Likewise, I would think if I had a SBC I would sure give that AFR Titan composite intake a good try. Anybody try it?
Jeff Lee 7494 D/S '70 AMX
Old 09-11-2013, 08:57 AM   #5
JCChildress
We ran one of the Titan intakes on a 421 SB Chevy bracket engine we did. It ran pretty good but nothing to do cart wheels over.
Old 09-11-2013, 10:35 AM   #6
SSDiv6
I know of many that have made more power with the composite intake over any other offerings in the market, both on the dyno and at the track.
They have also found the intake runs way cooler.
Old 09-11-2013, 01:20 PM   #7
Jeff Lee
Jeff Lee's Avatar
Unless it's just a poor runner / plenum design, I find it hard to believe it doesn't make more power just because of the cooler intake and vibration control (which I'm assuming it has).
Anybody know how the AFR intake compares to, say a, Victor, Victor Jr. or Bow-Tie intake? Isn't it odd I'm asking about Chevies?
Old 09-11-2013, 03:43 PM   #8
SSDiv6
Do a search in SpeedTalk. A few people tested the intake and did comparison tests.
Old 09-11-2013, 04:53 PM   #9
SSDiv6
Some links:
http://www.carcraft.com/techarticles...t/viewall.html
http://www.speedtalk.com/forum/viewt...33413&p=400429
http://www.speedtalk.com/forum/viewt...33534&p=401379
Old 09-11-2013, 06:30 PM   #10
Tom Nolan
I also tried the plastic intakes....both styles. Dyno'd the heck out of it! Spent the money to fill and profile the ports to match the heads. What did we find.......well not much, it was within 4hp lower of course. Tom Nolan.
