Old 09-13-2013, 06:24 PM   #1
SSDiv6
Default NHRA Tether Rule Update
http://www.nhraracer.com/content/gen...756&zoneid=132
Old 09-13-2013, 06:28 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: NHRA Tether Rule Update
Looks good to me. I'll fire up the TIG welder.
Ed Wright 4156 SS/JA
Old 09-13-2013, 09:04 PM   #3
63corvette
Liked 361 Times in 104 Posts
I think I may have struck a nerve earlier this week by submitting a design and stating I had no interest of producing them.
I do not like the two current designs so I came up with my own and submitted it to Glendora and my Division Tech director.
Seems a little strange we get a new revised rule in the same week as my submission.
My neighbor has a Ornamental Iron works so he may want to start producing the tethers as they are cheap to build and looks like with current pricing of the approved ones there is a good amount of profit to be made.
I built mine in less than an hour for under $30.
Below are pictures of the tethers and part of what I sent to NHRA.
Just My 2 Cents
Rick Cates
The design is just a one piece 3/16" stainless steel rod with eyes forged on each end to length for my Davis C-5 Corvette roadster headers which the pictures are of.
The loops are large enough to fit over the 3/4" wide stainless steel T bolt clamps studs with enough room for expansion of the headers as they heat up. Shown in pictures.
The clamps have a stainless steel aircraft grade nut to hold them under high temperature and vibration. I had to order those so the pictures are of a nylox nut which will be replaced once the aircraft lock nuts come in.
The only attachment points for possible failure are those 1/4" fine thread T bolts and aircraft nuts on the clamps.
This design is much simpler with less connection points than what is currently approved and I would like to have approval for my design for my use.
Name:	collector tethers 001.jpg
ID:	21279   Click image for larger version
Name:	collector tethers 004.jpg
ID:	21280   Click image for larger version
Name:	collector tethers 005.jpg
Name:	collector tethers 007.jpg
63corvette is offline   Reply With Quote
Old 09-13-2013, 11:06 PM   #4
Charlene Gullett
Charlene Gullett's Avatar
Liked 7 Times in 2 Posts
Hmm, it appears that some believe we are not all smart enough to figure out how to secure our collectors without an "approved device" This device also took less than an hour to manufacture and is less than $20. This was our solution. This is not one made with those expensive swageless eye aircraft fittings, but this wire rope thimble and ferrule have been an industry standard for years. It should prevent a 2lb collector from flying into my opponents lane.
6521 GT/MA 85 Cutlass
Charlene Gullett is offline   Reply With Quote
Old 09-14-2013, 04:26 PM   #5
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
"The NHRA Technical Department will not accept Tethering System requests from individual racers, as this will inundate our resources and create an impossible situation to regulate in the field. Therefore, material sent from individual racers will not be reviewed for acceptance. Only legitimate manufacturers planning to market a tethering system should submit a request". This means if you do not kick in or contribute to the NHRA in any way , Don't bother!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 09-14-2013, 05:32 PM   #6
SSGT Mustang
Liked 204 Times in 54 Posts
Maybe this question has been asked before since it's so incredibly obvious, but why don't they just print the requirements for what would be considered a legal tether and be done with it?
Not a requirement that you have to use one manufactured by a vendor, but something similar to any other general requirement, such as....what would be considered a legal roll bar/cage? You make the tether according to the requirements, or you don't pass tech. Simple as that.
An SFI approved tether? That's just insane.
SSGT Mustang is offline   Reply With Quote
Old 09-14-2013, 05:56 PM   #7
63corvette
I agree.
We can fabricate/build our own cages etc. but we are not skilled enough to build a header tether?
I have mine installed right now and plan on having the tech personnel look at them at the next two Division races and two National events before the end of the race season.
I do not really want to but I will add the 1/2 inch welds on each tube before I purchase a set of Approved tethers as set forth in the rules. I feel the 1/2 inch welds will crack with expansion and contraction during the heat/cool process but that is what NHRA wants I will do just that and leave my tethers in place.
From what I have heard and read from other racers this is a major issue with the way NHRA has handled it. I just do not understand why NHRA wants to run their racers off over such a silly new and my way or the highway rule.
Just My 2 Cents
Rick Cates
By the way my compete tether system was fabricated for less than $30 for both sides.
Old 09-15-2013, 12:24 AM   #8
treessavoy
Liked 4 Times in 4 Posts
All this Bull S**t over a non-problem, incredible!
JimR
Jim Rountree
Old 09-15-2013, 03:35 AM   #9
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Originally Posted by treessavoy View Post
all this bull s**t over a non-problem, incredible!
Jimr
exactly...............
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 09-15-2013, 07:12 AM   #10
David Lee
Liked 346 Times in 126 Posts
just another way fo for the NHRA to extort money from manufacturers and racers,
