#51 | |
Jeff Lee 7494 D/S '70 AMX |
#52 | |
They should also change the "bolt" ruling to say that each tube that goes into a collector have its own bolt and brackets, this would allow for differences with 421 type headers verses 4into1 headers. I understand the ruling is 4 bolts per collector, referring to a normal 4into1 collector? I am not aware of any foolproof way of keeping headers intact besides a regular maintenance inspection of hardware as it is subject to intense vibration and will fail given enough time. NHRA guys are not going to get under every car and make sure that even their "bolted" retaining devices are still intact. The whole thing is obviously a attempt to limit exposure to lawsuits and throw them off onto manufacturers instead of those organizations who don't or can't inspect cars they let run on their track or work to protect their "customers" from being hurt at their events. |
#53 |
Liked 316 Times in 67 Posts
My Nomad has fender well headers, very obvious to tech, I'm curious how tech will go checking low-to-the-ground Colbalts, etc with headers tucked well under the frame.....our SS/MA '57 needs a trans blanket and never once has tech knelt down and looked.....I suppose some might be visible from engine compartment
#54 | |
Liked 136 Times in 49 Posts
#55 | |
Ed Wright 4156 SS/JA |
#56 |
Ed,
Many race cars require disassembly of the headers to get them on & off the car. Heck, you can't even change the starter on my car without taking the collector off and loosening the flange bolts up @ the head. Stitch weld them up and they are on the car until you take a sawzall to the headers!
#57 |
Ok.
#58 |
Liked 705 Times in 204 Posts
If I can build a set that matches for $65.00 how would anyone know?
Products are on Amazon: Sucor stainless steel swage eye (I guess I need to figure out how to get the orange coloring...lol) Pro tie T bolt stainless clamps Flexlock ss nuts Stainless wire rope. Last edited by Mike Gray; 09-18-2013 at 06:45 PM. |
#59 |
Liked 280 Times in 139 Posts
Is there a stamp on the clamp?, does it come with some cert.? If tech asks if you have a approved tether and you lie and there's a way they can tell, you'll be kicked from that race, and probably fined.It's worth it for nhra to have the tech guy do the lambada under your car if they can catch a ??$$ fine.
#60 | |
The swageless terminals are used for boat and architectural rigging. Nevertheless, if you build it yourself, is not NHRA approved. |
