#31 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
#32 |
Liked 13 Times in 7 Posts
Joe, I need to find out how the injectors are powered. There are enough wires under the dash that it will take some time to figure all this out. Also, crawling under the dash is an event in itself!
I talked to MSD again today...and I will do a resistance check on the crank trigger pick-up tomorrow. He said the reading should be between 65-85 Ohms. With this and a noid test, I should have enough info to determine the source of the problem....then finding the root cause may be another journey. |
#33 |
John, having a spare crank sensor is a good idea regardless, however it seems apparent that it is not the cause of your problem, unless of course your no start "fixed" itself during your test. Do you know what switch you turn on to power the injectors? This would narrow the search a bit. As I've stated I'm not familiar with your system however can you "real time " communicate with it via a laptop and if so does it display any active parameters? Such as engine RPM? If so then you could monitor for RPM while attempting to start which I would expect to see, then during a no start event see if it is in fact displaying RPM. Hope this isn't too confusing. Joe
#34 |
Joe, Don't know which switch fires the injectors. I will assume it's either the ignition or fuel pump switch. Will be part of my "trace the wires" event tomorrow night and this weekend.
Relative to your other comments, I'm not familiar enough with the laptop interaction with the ECU to understand what you mean. This stuff is all new to me. |
#35 |
Ok, can we assume that you have had the laptop connected at all? If so then you'll just have to look around and see what info is displayed, but I'd bet you'll be able to see engine rpm. That would help in determining whether the ECU "thinks" the engine is running. I would like for you to have comm. via laptop as soon as you can as it may help find the issue.Quickest way to find the power source I would think is to use a test light at the injector connector and start trying switches, the 1 that makes the lite come on is it, then it's a matter of tracing that 1 circuit. Once you get a bit more info you'll be fine, knowing how things are wired up is a huge step in the right direction.Please keep us updated on your progress and good luck. Joe
#36 |
Liked 1,987 Times in 599 Posts
Just freshened my engine. Now it won't start. No spark at the plugs. How do you check the pick up on the crank trigger with an ohm meter. Using a 7AL box and crank trigger. Carburetor set up. Just looking for some ideas. The coil is nearly new. The MSD parts are older but have been real reliable.
Mike Pearson 2485 SS |
#37 |
Liked 557 Times in 217 Posts
There are 2 types of pickups. Magnetic and non magnetic.
Both have a coil of wire inside them and if you use an ohmmeter acorss that coil you should get a reading. I don't know what that reading is or should be for various pickups.....but an open reading would clearly be N/G The wire is super fine and many turns. MSD uses the flying magnet style and the magnets are in the wheel. The pickup is non magnetic. With the ignition on.....you usually can get a spark out of the coil by connecting and than disconnecting the trigger wires that go to the MSD. 1 spark every time you break the connection..... If you had an MSD tester you could test the box and the coil. Pickups get blamed for a lot of ignition issues and routinely replaced but I really don't think they are usually the cause of most problems.... In the generator world that I work in .....similar pickups are used to generate a signal from the engine to a controller. We change them a lot when something is not working right but like I said I don't think they are ususally the problem unless they clearly have physical damage. If anything rubs the pickup face then it is likely to be damaged inside.
#38 |
Liked 81 Times in 45 Posts
I have been working on this stuff since it all started, Certified mech for 30 years. I went to a A/C Delco class many years ago and learned that the magnet type makes A/C voltage when cranking. I believe the spec is 3 volts. I can dig out my old books to confirm if needed. That will confirm signal strength which can cause intermittent problems.
Kirk |
#39 | |
#40 | |
