Old 10-08-2013, 09:57 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968 396-375HP Block, Heads & Crank
1968 396-375HP standard bore 4 bolt block cleaned and magged in excellent original condition. 3935440 casting dated E-6-8 stamped T0508MQ 18N435876. Block at worse will clean up at 10 under if it cannot stay standard bore. I also have the 3919840 square port heads both dated D-23-8 in stock condition along with the 6223 steel crankshaft. Will seperate the parts out or sell as a package. I do also have the aluminum square port intake but it is not dated to the motor. Can ship if you cannot pick up and can be reached at 330-770-2517. Pictures can be provided with an email address and have paperwork from machine shop work as well.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
