Old 10-08-2013, 01:28 PM   #21
BRETV
Liked 776 Times in 199 Posts
Default Re: 85 5.0 Mustangs
I ran an 87 GT from 2000 thru 2003. We went 11.90's in M/SA with more left in it. So not all 5.0's have to be 85's. But actually I think the 85 head flows better than the 87-93 E7TE head.
Bret Velde
BRETV is online now   Reply With Quote
Old 10-08-2013, 02:58 PM   #22
Capri
Liked 27 Times in 14 Posts
We all know my 86 heads don't flow at all.
Capri is offline   Reply With Quote
Old 10-08-2013, 03:02 PM   #23
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Originally Posted by Rory McNeil View Post
Like Sean said, the 85 4 barrel heads are esentially the same as the 83-84 heads, in fact the same D8 heads were used on 302 2 barrel from 78 until Ford stopped making them. The only change for the 85s E5 casting was to add a clearance notch to allow the removal of the taller hyd. roller lifters without needing to remove the heads.
^^^ Thanks for the clarification.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-08-2013, 03:18 PM   #24
west coast
Liked 227 Times in 74 Posts
Jim
Bobby Fazio I believe runs or is going to be running a foxbody, he is on the east coast and my be helpfull he is also a stick guy. Sounds like you aready have the car what model? PM me can give you my number. On the trans Rory is right do it right the first time it will cost less money.
west coast is offline   Reply With Quote
Old 10-08-2013, 05:27 PM   #25
Slickfoot
Liked 2 Times in 2 Posts
It is 89 HB LX 5 speed , It ran 9.2s in 1/8 on street allseasons tires. When I was out with my foot I did the battle boxs, welded the tubes, Moser axles, studs, and c-clip eliminators, pro 3:90s , and a spool. Grantelli double adjustabe w/ hims on body side uppers and Lakewood liftbar lowers. I have not been able to run since, because of a problem with a over heating right rear brake.
Jim
Slickfoot is offline   Reply With Quote
Old 10-09-2013, 07:06 AM   #26
Chris1529
Liked 70 Times in 29 Posts
A 3.90 gear is not nearly low enough if you are going to make this a full time race car.
Even with a 26" tire, that is too high of a gear.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 10-09-2013, 10:41 AM   #27
west coast
Scott sent you a PM.
Old 10-09-2013, 09:28 PM   #28
Slickfoot
Chris
I got thid car a year ago Sept. It is a one owner never driven in the snow car. So each change I make in the car I keep all the parts I replace, incase my son someday wants to put back to stock. When I wanted to do the rear part of the car. I bought a rear end that was started to be built for a bracket car and the 3:90s were in it. It works for now with the 3:35 ist gear and 25in. tire, but your right as I move to the trans and than engine it will need a much bigger tire and lower gear .Thanks for the help and I hope you will be there for this old man as he tries to race with the kids.
Jim
Old 10-10-2013, 07:15 AM   #29
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
What about the Klacik Brothers?
Mitch Beri- The Motor City
Old 10-10-2013, 10:14 AM   #30
Slickfoot
I don't know them , should I? I been out of racing for a long time.
Jim
