#41 |
Liked 239 Times in 114 Posts
I think GM actually made a spacer for production vehicles to use a 298 mm converter with an LS engine. I don't have access to any parts books, but should be something a good GM parts guy could look up. I think they were used on LS, F-bodies.
#42 | |
Liked 5,153 Times in 1,967 Posts
Why I say a crank adapter would be better...
#43 | |
#44 |
Liked 35 Times in 6 Posts
Rule book is unclear about rear suspension. Are we allowed to replace the lower control arms and the the track locator bar with aftermarket? And What about Frame connectors ? Also the torque arm. I want it off of the rear of the trans. Are we allowed to build a support for that as long as it is part of the trans crossmember? ? I know I saw a 70s camaro with slapper bars at Norwalk a few years ago so I would assume you can use them for Leaf springs. Thanks Aaron
#45 | |
If this is a IHRA Pure Stocker. I know Joe Marcinowski out of Cleveland, Ohio ran "bolt in" frame connectors on his late 70's Camaro when he ran P/S. Pretty sure he had slapper bars as well. As far as removing the torque arm on a later Camaro, may have to question someone with IHRA tech info. Contact Mike Baker or the Division Director, they could give you an answer.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#46 | |
Guest
Posts: n/a
Let us know when you find something out. Scott |
#47 |
Liked 360 Times in 121 Posts
Interested to get the official word. From what I gather some is legal some not. If it has heim ends and is "ultra adjustable" its a red flag in tech. I plan on using the stuff that has poly bushings and appears close to stock. If I can put in a Strange/Moser 12 bolt there has gotta be some leeway. I plan on weld in subframes and a moly 6-point as well.
#48 |
