#11 |
Liked 905 Times in 193 Posts
If collectors are bolted to cross member, would that satisfy requirement?
Bob Don 128 SS |
#12 |
And there's the X-pipe systems that are hung via a hanger set up to the car itself. Just consider how many things have to fail for a collector to come off that setup.
Doug Blackley 1697 STK |
#13 |
And please remember that some of us still try to squeeze out a little bit with primary extensions if required in certain situations. Also welding on some coatings will fail even when the surface is ground to clean metal. Embrittlement or something similar.
I'm not particularly fond of having a collector on a wire flopping around under my car possibly puncturing a front tire or severing a brake line or igniting my oil soaked engine diaper from sparks flying etc. etc. |
#14 |
Liked 535 Times in 110 Posts
Any news from SRAC meeting regarding rule changes?
Jim Kaekel 3836 STK |
#15 |
Liked 325 Times in 50 Posts
Basically not a lot of objection from the racers according to the members, just lots of objection to the price. I have a local source that can make those things. I'm going to send NHRA a set and get it approved. Will be cheap. How about Cajun Connectors for the Collectors? Nice ring.
Jeff Teuton 4022 STK |
#16 |
Liked 370 Times in 101 Posts
Thanks, Jeff!!!! any changes to Stock Eliminator cylinder heads for 2014!!!!
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#17 |
Liked 100 Times in 45 Posts
Discussion point (#23) was about fuel/weight check after heads up runs (only heads up discussed).How about ALL semi and final rounds???????Oh I forgot the scales and fuel check equipment are already closed/dismantled at that point.Something about Miller time I think.
Former NHRA #1945 Former IHRA #1945 T/SA |
