Old 10-22-2013, 12:04 PM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Accumulators
I am looking to purchase an engine oil accumulator this winter. Are there other brands available?
Moroso, CVR.....???????
Thank you
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 10-22-2013, 12:19 PM   #2
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Default Re: Accumulators
Thank you
Ian
Accusump have always worked well for me!!
http://www.accusump.com/
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 10-22-2013, 12:20 PM   #3
Keith 944
Keith 944's Avatar
I bought a canton and love it, use as a pre-oil @ start and dumps if under 25psi. bought the electric solenoid so it dumps @ startup when I hit the ign. switch.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-22-2013, 05:43 PM   #4
Stock726
Liked 35 Times in 10 Posts
Ian, you have a PM.
Stock726 is offline   Reply With Quote
Old 10-22-2013, 07:03 PM   #5
tj310
First one of those I ever saw was just an hyd. cyl ,guy said it came of aeroplane landing gear. ---Trevor
Old 10-23-2013, 01:46 PM   #6
Ian Hill
Ian Hill's Avatar
that must have been impressive. so when the oil pressure went down did the cylinder rod extend the front suspenion allowing the oil to run to the back of the pan??? LOL!!!! we may be onto something here call the patent people quick.
more specifically, i am not interested in the accumulator for its pre-oiling capability, although it will be a gained benifit. i will be only requiring a 1 quart accumulator. i am looking for an accumulator with an aluminum barrel and the lightest possible weight.
in the hydraulic business we fill the nitrogen portion of the accumulator to 60% of the working pressure. is this the standard for low pressure systems (i.e. our engines oil system pressures of <60psi)?
any help is appreciated. worse case i guess i could go buy the cheapest version, read the instructions and then decide if i want to build a light weight unit or not.
Regards
Ian
Ian Hill
Old 10-24-2013, 01:00 AM   #7
HP HUNTER
Liked 373 Times in 129 Posts
A must have.
