Old 10-28-2013, 11:03 AM   #11
Philip Baise
Default Re: Carburetor idle air bleeds
Try this, On the sec. shaft there is a screw that will help adjust the idle. With a 3/32 allen wrench turn this screw 1/4 turn counter clockwise, then adjust your idle on the primary side to compensate for that . Mixture screws in the sec. should be 1 and 1/2 turns out. The primary screws can be 1 or 1 1/2 out (which ever is best for you. And the bleeds were staggered on purpose, 73 pri, 68 sec. Hope that helps.
Philip Baise is offline   Reply With Quote
Old 10-28-2013, 11:43 AM   #12
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
So is there going to be a problem by me swapping over air bleeds,68 fronts,73 rear, for now it idles better and i have control of the mixture screws.I also backed down on the secondary allen screw.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 10-28-2013, 12:11 PM   #13
Philip Baise
Thumbs up Re: Carburetor idle air bleeds
I told you wrong on direction to go(looking upside down on my part),turn the allen wrench clockwise . No it wont hurt at all, Get the idle where it fits you the best.
