Old 10-30-2013, 06:49 AM   #41
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: Looks like hp on Tuesday
Originally Posted by RJ Sledge View Post
Would you believe 678hp with the new optional camshaft/cylinder head pieces that Ford is releasing for the 2014 season.
Make my Day!!
RJ
Speaking of balls! I can't believe you posted that. Thanks RJ
Pedigo Perf is offline   Reply With Quote
Old 10-30-2013, 07:05 AM   #42
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Make my Day!!
RJ
675hp sounds more realistic.
Old 10-30-2013, 10:01 AM   #43
Ed Wright
Ed Wright's Avatar
Originally Posted by Andrew Hill View Post
Absolutely. I would think it would make quite a bit more HP than a super stock LT1, and I assume you saw the qualifying sheet from Bowling Green this last weekend? The 352 at 330 HP is more under factored than an LS1 was at 305 or an LT1 was at 275.
They make quite a bit more than my SS LT1.
That HP hit didn't hurt them at all.
Ed Wright 4156 SS/JA
Old 10-30-2013, 10:27 AM   #44
RJ Sledge
Liked 294 Times in 93 Posts
Yup......and it makes that on a bad day!!!
We're selling it though, want to build the 428 Windsor Combo, can't believe it will make over 880hp with the" new improved" pieces for 2014. Ford is releasing the info at SEMA this week, so keep an eye out for the news.
Hope to get some power knocked off so we can be competitive with the Copo's and the new Dodge's. It needs about 35 hp taken off. But it nots a Chevrolet so might be for naught. Maybe get ole Greg Hill to give us some pointers LOL.
RJ
RJ Sledge is offline   Reply With Quote
Old 10-30-2013, 10:47 AM   #45
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I guess I missed it. When did someone get 35hp off?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-30-2013, 11:00 AM   #46
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
The 1970 LT1 like I run was rated at 360 hp from the factory, but is rated 325 now, as it has been for many, many years. I don't think anyone in their right mind would consider building one at 360.
I want to know how to get smaller rod journals, a bigger carburetor, and Edelbrock heads legalized for my combo, or is that just ok for Fords?
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 10-30-2013, 11:24 AM   #47
RJ Sledge
Ed
Its just a guess you understand.....but I think it was the 1970 350/360 hp Camaro Combo that somehow got a 35 hp reduction at the beginning of 2003. I believe it is now a whopping 325 hp.
How many times have you seen that happen??
Makes you wonder! LOL
RJ
Old 10-30-2013, 11:57 AM   #48
Jeff Teuton
Liked 325 Times in 50 Posts
Andrew, you got a 780 Holley which will flow more than a 1000 cfm throttle body. A 1000 cfm has 750 holes in the bottom. Looking at the specs on your motor, makes mine look like the truck motor it is derived froml 11 to one, same roller rockers I got, same cam, choice of 8 heads, some new manifold that nobody knows about, big carb (whichcfm for cfm will make more power-according to the manifold makers) and 325, all the 350's in 70 and 71 are suspect. If I had that I could run 9.70s and RJ could run 9.60's cause he is a better tuner. I guess you guys are in your right mind. I had a 35 Hudson Teraplane fastback with a V12 Hemi that got 10 off, and Sammy P. has gotten about 200 off that 427 thing he runs. RJ, nobody likes us old guys. I'm gonna complain to the AARP.
Jeff Teuton 4022 STK
Old 10-30-2013, 12:00 PM   #49
Comp 798
Comp 798's Avatar
From: Kershaw, Jesse (JM.) (jkershaw@ford.com) This sender is in your contact list.
Sent: Wed 10/30/13 2:46 PM
To: 'Sam Tufano' (sam_tufano@hotmail.com)
I’m not sure what RJ is talking about. We aren’t releasing anything.
We are working on a new 429 for the 2014 model that has different heads but they would not be backwards compatible.
Sam Tufano
Comp 798 is offline   Reply With Quote
Old 10-30-2013, 12:08 PM   #50
Andrew Hill
Still 5 more than that 390 with all the aftermarket parts. It's also the second highest rated carbureted small block in the guide (behind the same motor in the Corvette, 5 hp more).
[ame="http://www.youtube.com/watch?v=Qw9oX-kZ_9k"]Whatcha talkin bout Willis - YouTube[/ame]
3207 D/SA, C/ED
